deema
I thought I might share how I bring an overlooked hand saw back into being a very useful thing. This is my method, step by step, I'm sure others will both help me and anyone reading this by suggesting improvements and ways in which I can do it better. All comments are gratefully received.
I was inspired to write this by both all of the sharing of restoration done by others, I don't pretend to be an equal to the high quality work I've seen on this forum and also by a new woody who wrote in the forum who was looking for advice on their first hand saw.
For anyone new to wood work, the first hand saw they normally pickup is normally a in-expensive hard point saw from a DIY store. These saws are fine IMO for rough DIY but for anyone trying to make joints they leave a lot to be desired and can I'm sure put people off.
So, for a grand investment 99p anyone can obtain a saw that with a little time and effort can be as good as the most expensive saws you can buy (again that's my opinion)
So, first things first, either look up your nearest car boot sale or start looking on auction sites for a hand saw.
The first question is often what to look for, well a hand saw is basically only as good as the teeth that cut the wood and this is determined by the quality of the steel. The better steels are found on either high quality modern saws such as a Pax who are the last saw makers in the UK or alternatively, an old saw. For a 'rags to riches' saw your not looking for anything fancy. Pistol grip saws tend to go for a lot of money, so a closed handle may not look as nice, but is actually stronger and more resilient to being dropped. Generally on an old saw it will have a wooden handle, which is highly likely to be beach. Don't worry about how 'crappy' I looks that's soon solved with little sand paper!
Brass back saws cost more to make than steel and is a good sign that it was a quality saw in its day, so my suggestion is select one with a brass back.
Don't get hung up about brands, rather look at the overal quality of the saw that lies beneath the grime. If the teeth are missing, uneven, dull, smile with glee, your going to sharpen in and that puts a lot of people off making it cheaper.
Select a saw that does not have split nuts on the two, three or four 'bolts' holding the handle onto the blade. Look instead for a saw with nuts that you can use a normal screwdriver on. Nothing wrong with split nuts apart from
1. They need a screw driver adapting to fit the nut
2. They are generally weaker and more brittle and break easier.
Lastly, sight down the blade and check that the blade is not kinked. It may be curved or an S shape, but what you don't want is any sharp and sudden changes in direction. Anything else is easily fixed.
