Dave's Metal Stuff
DTR
11 Mar 2011
Essex
I've been doing more metalwork jobs than woodwork as of late, so I thought I'd post some stuff up.
My Hobbies wood lathe has a blind morse taper socket in the spindle, so I can't just bump out the centres from the opposite end. Apparently this is quite common on older lathes. Until now I've been twisting the centres out, but I've never been happy with this. Then when Doris bought her Coronet, I realised this has a centre ejector. It screws onto the spindle nose, and simply pulls out the centre when unscrewed. I thought this was a brilliant idea, so I endeavoured to make one....
I started by making a mandrel threaded the same as the Hobbies spindle nose. This will serve as a gauge for the ejector's internal thread, and also as a way of holding the ejector for machining:
Then I hacksawed off a lump of bar for the ejector. I chucked it, faced off one end, then flipped it over and faced off the opposite end. Then I drilled a 1/2" hole straight through (sorry, no photos).
Next I bored the hole out to the tapping size of my spindle nose (7/8 BSW). This is a blind bore, leaving a "cap" at the end of the ejector. Then I screw cut the internal thread. I cut the thread almost to full depth:
And finished the thread with a tap:
Now the ejector can be screwed onto the mandrel and the two are mounted back in the lathe. A skim cut is taken to clean up the outside:
And then the ejector is knurled:
Finally the knurling is tidied up:
The almost-finished ejector. All that's left to do is to drill a hole for a tommy bar, just in case it gets stuck
Neat, tidy and very satisfying!
I've got something similar on my wood lathe, bought from Axminster and called by them a "thread protector." But it's more fun to make your own than scout around for the right size, in stock etc.
Nice bit of work there DTR, you should be very proud of that. =D>
Especially the knurling - nice and "crisp & deep & even"! (not easy to do when you start off - DAMHIKT).
Thanks for posting
AES
DTR":27nix4pw said:
Now in use
I do like the knurling, what sort of knurl did you use single or double and where can I get one from ?? I did have a single but needed a fair bit of pressure. Went with a lathe I sold
Thanks Timber
Hi Timber,
The knurler is a cheap, 2-wheel clamp type. I probably got it from RDG or Chronos, but I can't remember which now:
http://www.rdgtools.co.uk/acatalog/INDU ... 09087.html
I used to use a vintage 2-wheel "side pressure" type, the sort that carries two wheels on a pivot and ploughs in sideways. I think that one actually worked better, but I was wary of using it because of the load it imposes o the lathe bearings. Maybe one day I'll transplant the wheels from the vintage one onto the new one....
DTR":kdeea8me said:
The knurler is a cheap, 2-wheel clamp type...........
I used to use a vintage 2-wheel "side pressure" type............... but I was wary of using it because of the load it imposes on the lathe bearings
I have one of each and, like you I prefer the 'squeeze' type rather than the 'push' for the same reason. I seem to remember that you can buy knurling wheels on there own, so you can alter courseness or pitch etc., or just renew worn wheels.
Just had a look at Chronos's site, amazed, the knurling tools really are quite cheap.
Thanks DTR And Mike
I will have to order one. It does make ones work more professional.
I have a bit of kit that came with a job lot I bought that does similar decorative stuff on bowls etc. Haven't tried it yet as I am not into bowl making.
Regards
Timber
I strongly recommend the 'squeeze' type, better for your headstock bearing.
Tip:- after your first pass [left to right or vice versa] if you keep the knurls engaged you can then nip the pinch-bolt up a little and gently/slowly traverse back the way you came for a second deeper go.
+1 to that
This week's job - making a flycutter for the BCA....
Blank arbor chucked and turned down ready for screw cutting:
Screw cut the thread:
Drilled and tapped a lump of rod and screwed that onto the end:
Then I took a skim off the face and diameter to make it true with the arbor (no photos).
Next I clamped the flycutter into a vee block fixture bolted to the cross slide. This fixture holds round stock centred on the lathe centre height for cross-drilling. The vee block has been bolted down at a 45* angle to the lathe axis. A 1/4" hole is drilled and reamed for the tool bit, then the fixture is rotated 90* to drill for a clamping screw:
And finally the flycutter in place on the BCA:
More bits for the Hobbies wood lathe....
The Hobbies came with a homemade banjo, and the socket bore is bigger than the post on the tool rest. To take up the slack I'll make an intermediate bush. In hindsight I should have just made a new banjo, perhaps I'll come back to that.
Chucked a lump of steel and turned down the outside diameter to match the banjo. Then bored out the insides to fit the post on the tool rest:
Then parted off:
Next I'm going to split it lengthways so that it closes around the post when the banjo nut is tightened
I missed your Flycutter post, very handy tool. I bought mine and it takes a 3/8" sq HSS tool bit but I sometimes swap this out for a home made carbide insert holder I made for it The HSS is really nice on aluminium alloy but the carbide comes in handy for some of the tougher steels.
Nice job on the tool post adaptor. Will you use a slitting saw on it for the cut?
Thanks woodpig
Yes, I'm a fan of flycutters. I often used to use one made from an old 4" backplate on the lathe (it currently needs re-boring to fit the ML7). Good thinking with the insert holder; if I ever dip my toe into insert tooling I might follow suit. How do you find the inserts hold up to the intermittent cut?
Yes I'll be using a slitting saw. I made up an arbor for the BCA a few weeks ago; this will be its first outing
Once again DTR, you've shown that you're really an ace at making good quality useful stuff on the lathe - AND photographing it well too. Definitely an inspiration to "dabblers" like myself.
=D>
AES
Long story short Dave but I had the idea of using a round carbide insert in my flycutter but dismissed it as I figured an interrupted cut would chip the insert. A couple of hours later I read somewhere on the net about another guy who had the same idea and it worked fine. The inserts I use are 12mm round and are quite thick.
Update: found a picture of it.
The inserts are slightly concave as you would expect but you can sharpen them on a diamond plate and they still cut ok.
