mj23
New member
Hi, I am currently designing a product for a product design A level class, it will be a lamp.
I have included a picture of the design and would like some help on how to construct it, the design will consist of two parts, the base and the upper frame, I mainly need help and constructing the upper frame, my teacher has suggested making the frame out of MDF and then implementing lap joints or housing joints which I can then slide in bent aluminium pieces, which will cover the MDF, she warned me this will be rather complicated which is why doing extra research and seeking outside help.
My main query would be how I would initially go about constructing this and any other things I should consider/change, also what would be the best way of joining it with the base, I was thinking of using a mortise and tenon. The light source will go under the extended part atop the curve, this will then be covered with translucent acrylic attached by screws into small softwood cubes in the corners. Any other tips would be much appreciated and I'm open to criticism.
Furthermore I've pretty much got the base covered but any design input would be valued. I want to try and make it using dovetails as it would just be a cuboid box but I'm a noob when it comes to them, I plan on using cherry wood for it.
Thanks in advance.
Thanks in advance.
