 Reply
User avatar
By MikeG.
#1304803
Painting OSB (inside the building) can be done with the cheapest emulsion you can lay your hands on. There is absolutely no point using expensive paints such as Bedec or a masonry paint. Save Bedec for outside.
By DomD
#1304804
MikeG. wrote:Painting OSB (inside the building) can be done with the cheapest emulsion you can lay your hands on. There is absolutely no point using expensive paints such as Bedec or a masonry paint. Save Bedec for outside.
But will it need primed if I use cheap emulsion? If so what with?
By DomD
#1306803
Slower progress - I did install the windows:
Only to decide the white really doesn't fit with the building... I will be getting some custom sized wooden ones; if anyone has used any companies for windows I would be open to recommendations.
Then I made a door and similarly dislike the result; Mike was right about the design being too heavy so I will replace with a shiplapped/t+g door.
I also finished off gable insulation:
Onduline has been ordered for installation next week. Am I correct to assume the 'sag' in the roofing membrane would allow insects into the void below the onduline? If so how do I seal this? The corrugation profile will be sealed with a foam eaves filler above a batten.
Could the ridge also act as an opening?
By beech1948
#1306921
I can not see from your last picture but Onduline will sag between the roof members such that over 5 yrs you will have a 3" to 5" sag which collects and holds water. Onduline has no strength to resist this. Guess how I know this.
If still using Onduline then you need to provide either ply (1/2") or 3/4" OSB for the Onduline to sit on.
