UKWorkshop Woodworking Forums
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
Author Message
PostPosted: 30 Dec 2017, 20:24
Offline
Valued Contributor
User avatar
Has thanked: 312 times
Been thanked: 286 times
PattyMac wrote:
I've rubbed down, applied knotting soln., primed twice with a rubbing in between and applied three coats of satin - again with a rub down and they still look - to me - new and awful.
To me that sounds like the paint was awful (unless it was not mixed thoroughly or had gone off). While most paints should not be expected to give solid coverage with a single coat, any halfway decent paint should give a complete 'fully painted' look after the third coat is on even without primer applied first.
Just for a point of comparison the cheapest paint I can buy will cover well in three coats, the first two thinned to a milky consistency and only the third coat at full strength. Anything at all decent when used undiluted should cover at least as good as this.
_________________
"There is possibly more mystique in finishing than in any of the woodworking skills, and with (arguably) less good reason."
Aidan Walker
 Profile
PostPosted: 30 Dec 2017, 21:00
Offline
Participant
Has thanked: 0 time
Been thanked: 1 time
ED65 - the paint was a Dulux SatinWood Quick Dry - bought new and stirred well. Personally I think it's the wood - it just seemed as though the grain wouldn't cover and kept showing through - if that doesn't sound stupid. I have just put it down to the wood - yes, it was pine but from a local supplier and supplied as bog standard "architrave" (spelling probably wrong!).
We also bought three new doors which have 15 small bevelled panes in them which I had to do from raw wood (think this was hardwood). Again, using the same paint I had to apply two coats of primer and three coats of gloss. They do look well but a heck of a lot of work - painted them flat on my big dining table. One thing - these doors had the plastic on the front of the glass and were much easier to paint than the same ones we'd had many years ago - just have to be careful slicing the plastic off afterwards.
We got the white skirting board (is it MDF?) and again I wouldn't recommend - I thought I wouldn't need to undercoat it but as it needed rubbing down the finish came off and I had to undercoat it.
We've come to the end of the project at home which was a kitchen knocked through to the dining area, new staircase and a shower room downstairs - back to France in the Spring.
As you've probably guessed .....the decorating is left to me - keeps me busy and other half does the building etc. - definitely no patience...!!
Perhaps I just like to see a completely smooth finish like we have on the other paintwork in the house which has been done a few years - is this the case??
 Profile
PostPosted: 30 Dec 2017, 21:37
Offline
Prolific Contributor
Has thanked: 24 times
Been thanked: 343 times
You can't blame the wood if the paint is cr&p.
Linseed oil paint will cover almost anything in two coats. No primer (though you can use linseed oil itself), no thinners, easy clean up of brushes, no waste, lasts much longer than Dulux and all modern cr&p paints.
 Profile
PostPosted: 30 Dec 2017, 21:40
Offline
Participant
Has thanked: 0 time
Jacob,
If it's oil does it yellow more quickly? Also, I thought oil-based paints needed turps to clean brushes after??
 Profile
PostPosted: 30 Dec 2017, 21:47
Offline
PattyMac wrote:
Jacob,
You can buy linseed oil paints in as fine non yellowing quality as you want - it's what artists use traditionally, but the best is pricey.
You don't clean the brushes you suspend them in oil (jam jar, hole in lid, clothes peg) until the next time. It doesn't dry like solvent paints and they stay in good nick for a long time.
Lost of threads about it recently - have a search.
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 4 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
 Similar topics   Author   Replies   Views   Last post
Refinishing Pine Furniture
in Finishing Advice
paulrockliffe
7
639
19 Feb 2017, 19:45
Been painting the town red
in General Chat (Off-Topic)
Claymore
9
538
21 Dec 2017, 16:32
I hate painting . . . . but
in Scrolling - Scroll Saws
bodgerbaz
32
1152
19 Mar 2017, 06:47
Painting hardboard...
in Finishing Advice
GrahamRounce
5
384
24 Jun 2017, 10:30
Painting over render
No skills
10
674
28 May 2017, 16:45
Register UKW
User Tools
UKW Local
Quickly find the nearest tool suppliers & timber merchants in your area
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
UKW Terms & Privacy
