Moderators: Random Orbital Bob, nev, Noel, Charley, CHJ
 Reply
By Alder
#1193415
If using a sheet of ply for a router table am I correct in thinking that a collet extension is required or you will only a minimal depth of cut?
Russell
By Stevedimebag
#1193420
Alder wrote:If using a sheet of ply for a router table am I correct in thinking that a collet extension is required or you will only a minimal depth of cut?
Russell
I will be routing out a recess for the router base to sit in below the surface of the table. Might take 5-6mm off my cut depth but I am ok with that.
By Rorschach
#1193449
If you remove the plastic base from the router you will gain about 5mm extra depth of cut, that's what I did and I removed enough material from the back side so that it equalled the thickness of the plastic plate, therefore I haven't lost any depth of cut at all with my table.
By whatknot
#1193453
Can you expand on the part about a lead on pin please
And do you mean for use with the type of bit as per attached?
If its that type of bit, whats the need for a lead pin?
Just trying to understand if I need one and why
E.
Small PS: I'd add a removable block nearer the router, as a "lead-on pin" for bearing-guided shape routing "freehand". But it's a very simple thing and will only take a few secs to do whenever you first need it.[/quote]
By Stevedimebag
#1193459
Rorschach wrote:If you remove the plastic base from the router you will gain about 5mm extra depth of cut, that's what I did and I removed enough material from the back side so that it equalled the thickness of the plastic plate, therefore I haven't lost any depth of cut at all with my table.
yep - was thinking of this too - just have to check my router base and see how to get it off.
By PaulR
#1193508
Sorry to hijack the thread (slightly) , what sort of wax do you use to make plywood slick ?
Paul
Sent from my SM-G903F using Tapatalk
By sunnybob
#1193542
The starter pin is vital when you are first starting out.
If you don't use one, when you first put the wood to the cutter it will grab and throw the piece clear across the room.
You should place the wood firmly against the starter pin, make sure your fingers will not get anywhere near the bit, and slowly rotate the wood into the bit. Once the cutter is fully into the wood and the top (bottom) bearing is engaged with the wood, you can then start to move the wood around the cutter.
Later on, with much experience, it is possible to do without the pin. I now just use the fence as a resting point, but still don't just go in freehand
By PaulR
#1194003
MattRoberts wrote:Pretty much any wax will do the job, even a candle. I use clear briwax
Thanks Matt
