 Reply
By chaoticbob
#1321345
Trevanion wrote:
chaoticbob wrote:Ben, this rang a faint bell and a look in my bits box turned up a length of 3/4" (19mm) brass round with an M8x1.25 hole threaded to about 40mm deep in one end - can't remember why I made it! If you're not sorted already I can cut off the threaded bit to 38mm - turning down to 18mm diameter if critical would be the work of minutes. Yours for postage.
Bob.
It's almost like it was meant to be :shock:
It was slightly weird - I remembered seeing a bit of brass in the short parts bin with what might have been M8 thread in the end, screwed in a bolt, lo and behold it was indeed M8 and went in about 40mm.
Reading further comments about this being a problem with other machines I wondered if an Acme or trapezoidal screw might be a better solution. I had a look at my own saw (Record 350, very much a hobby machine) and that's what they use for the tensioning mechanism. It must be an one of those areas where manufacturers cut corners.
Robin
User avatar
By thetyreman
#1321425
chaoticbob wrote:
Bob.
Robin
recieved the part today, thanks robin, delighted with it, absolutely perfect and exactly what I wanted, that was super fast!
By chaoticbob
#1321590
Glad you're happy - I have to confess thinking that as I should turn off the mill finish from the nominal 19mm bar I may as well swipe it down to 18mm in the process, and was dismayed when it came out as 17.96 :shock: .
I'd be interested to hear how the epoxy joint between the wooden handle and threaded rod holds up. I'd thought about something similar myself for a project, but wasn't confident that glue would be strong enough.
Robin.
User avatar
By Lons
#1321607
chaoticbob wrote: I should turn off the mill finish from the nominal 19mm bar I may as well swipe it down to 18mm in the process, and was dismayed when it came out as 17.96 :shock:
Shoddy, you need to calibrate your micrometer :wink: :lol:
I'd be interested to hear how the epoxy joint between the wooden handle and threaded rod holds up. I'd thought about something similar myself for a project, but wasn't confident that glue would be strong enough.Robin.
Just fix a reinforcing pin through.
User avatar
By thetyreman
#1321624
I'm still thinking about a better way to hold the handle in place, I will try the epoxy first and see how it goes, my plan is to epoxy in an insert into a piece of wood, glue some brass thread into it then glue that into the top of the brass shaft, if anyone has a better idea I would like to know, will have to see how it holds up, not all of the parts have arrived yet so there's time.
User avatar
By thetyreman
#1321630
what do you mean by reinforcing pin? sounds like a good idea though.
User avatar
By thetyreman
#1321722
MikeJhn wrote:As a further refinement, how about a cam and lever to de-tension the blade after use?
would love to do that but would need some kind of framework or plan, it might be something I do once this is fixed, I genuinely don't know how they work mechanically.
User avatar
By Lons
#1321734
Still epoxy the handle on then drill right through handle and rod with a small dia drill, insert a length of brass or steel rod / wire through ( a nail or panel pin can be used ), cut off just proud and hammer over the ends, finish off with a fine file and you'll hardly see it but it won't come off.
Or am I misunderstanding what you're trying to do? That happens quite often. :oops:
User avatar
By thetyreman
#1321752
cool thanks for the tip, now it makes sense, that's an excellent idea, no misundertsanding at all, cheers.
User avatar
By Robbo3
#1321789
I'll second Lon's idea. I did the same thing some years back when I mounted a keyless chuck onto a file handle to save holding drills with pliers.
