Moderators: Random Orbital Bob, nev, Noel, Charley, CHJ
 Reply
By Retired
#1265849
Hi,
Good luck if/when you have a go at metal spinning TFrench; your Wadkin lathe will be up to the job; I like Wadkin machinery which lasts forever if cared for but even if its abused it can easily be rebuilt mostly needing bearings and drive belts. I used to own a big heavy Dominion woodturning lathe but it proved too big taking up lots of workshop space.
You'll need to check the aluminium grade you have access to; I'm sure with practice any aluminium sheet can be turned but the correct metal spinning aluminium is the softest grade.
www.aalco.co.uk/datasheets/Aluminium-Alloy-3003-0-Sheet_59.ashx
1100-0 grade is even better but both 3003 and 1100-0 are the aluminium grades to go for knowing they will give good results during metal spinning.
Kind regards, Colin.
