UKWorkshop Woodworking Forums
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
Author Message
PostPosted: 12 Jan 2018, 19:13
Offline
Settled in Member
User avatar
Has thanked: 54 times
Been thanked: 56 times
I had the t7 tormek, sold it and bought the full Proedge kit. The t7 gouge jigs work on the Pro edge.
I love it, would never go back to a wheel system. You don’t want/need hollow grinds on turning tools.
I use it for normal chisels and plane blades, mower blades, axes, literally anything with a cutting edge.
Very rare to find one second hand, that tells its own story.
Phil
 Profile
PostPosted: 12 Jan 2018, 19:47
Offline
Participant
Has thanked: 0 time
Been thanked: 0 time
The Robert system does seem to be the rolls Royce option but I've just been reading about the slow speed bench grinders combined with white stones. Axminister and creusen seem very good. Anyone got views on these options as an alternative to the £340 Robert Sorbey option? Although slow speed bench grinders are expensive for what they are, it seems cheaper than "Bob Sorby!"
 Profile
PostPosted: 12 Jan 2018, 21:53
Offline
Settled in Member
User avatar
By the time you’ve added jigs (if you use them) the slow speed grinders aren’t really that much cheaper. I went the stone route, wished I’d never done it. The real problem comes when you want to reshape, then sharpen. Easy with Proedge, the grits are too fine for reshaping with white, and they need constant dressing else the develop wavy surface and deep grooves. Don’t fight it, just shell out once and never think about it again except smiling every time you walk away with a sharp gouge in 30 seconds.
 Profile
PostPosted: 12 Jan 2018, 22:13
Offline
Participant
Has thanked: 0 time
I like your way of putting it! I can see your logic......but £340?????
Anybody got a Robert Sorby they would sell?! I know I have already asked this in the “wanted” section of the forum!
 Profile
PostPosted: 13 Jan 2018, 19:37
Offline
Participant
Has thanked: 0 time
jim1950 wrote:
I'm looking into the same thing, I've got the tormek and can't make my mind up tormek jigs for tuning tools of Pro edge. Help please.
Hi Jim
I've sent you a PM.
 Profile
PostPosted: 14 Jan 2018, 11:19
Offline
Participant
User avatar
Has thanked: 7 times
Been thanked: 1 time
For what its worth I had the O'Donnel jig set up on a six inch grinder and also a Tru-Grind jig set up on a 8 inch Record Power grinder both fitted with whith white wheels, and still struggled to replicate my sharpening angles every time. I took the plunge invested in the Robert Sorby Pro-edge. Absolutley worth every penny to me, my turning has improved, less time spent sharpening tools and the tools are so much sharper than before and replicating angles is so easy. In hindsight I wish Id bought one first instead of the other two jigs and grinders which are now standing redundant in the corner of my shed.
 Profile
PostPosted: 14 Jan 2018, 15:39
Offline
Settling In
Has thanked: 11 times
Been thanked: 40 times
I started off with a budget grinder I found on gumtree and some cheapo jigs from ebay. As I got more proficient I thought I should buy a 'proper' grinder so I invested in the Record Power one. The spec is actually very similar to my original grinder so after it had lingered under a bench for a few months I decided to use it alongside the Record Power one. I also found that, with care, I could get pretty much the same results with the cheapo ebay jigs as I could with the Deluxe Universal Sorby sharpening system I bought.
I now have a choice of four wheels, (three white and a one CBN) set up for the four angles I use most - from left to right in the picture: one for spindle roughing gouges, scrapers, beading and parting tool, bedan etc, one for bowl gouges, one for spindle gouges and one for skew chisels. The Sorby system is split between two wheels, as I found it a right faff to keep resetting up.
This setup minimises the time setting up for a grind and maximises turning time.
I also have a Trend diamond sharpening card that I keep in my pocket that I use if an edge just needs a freshen up. I use that all the time.
 Profile
PostPosted: 14 Jan 2018, 16:58
Offline
Participant
Has thanked: 3 times
sorry Arnold, i would only sell you my pro edge for £340, so i could go out and buy another new 1, i rate mine that much, but like you i found £300+ a lot for a sharpening system, but since saving up for it and using it for the last 3 months, i think it really is money well spent, and build quality seems really good, i would hope it lasts me a Good many years, i like you waited for months for a good 2nd hand one , (they seem to be like rocking horse poo) and when 1 did come up they nearly reach new price,
good luck on whatever you decide
 Profile
PostPosted: 15 Jan 2018, 13:45
Offline
Participant
Has thanked: 0 time
Thanks for the replies...i have made my mind up and bought........
The Robert Sorby deluxe universal sharpening system. Handles are doing it at a discount but that's not why I'm buying it.
On Saturday I visited a colleague who is an excellent turner and he took me through the reasons why he has this option. He sharpened some gouges/chisel took me over to his lathe and gave me a demo to show how sharp they were and how well they cut. For s fraction of the price of a pro edge and still with excellent results why pay that much again?
Each one to their own and I'm not knocking those that have the pro edge, but as I need some more "boys toys" I felt thus was a good balance between expense and end results- sharpness. I also have some pound to spend elsewhere!!
Regards
 Profile
PostPosted: 15 Jan 2018, 13:47
Offline
Participant
User avatar
Has thanked: 0 time
Good choice.
_________________
Living and working on the Norfolk Broads.
 Profile
PostPosted: 15 Jan 2018, 22:30
Offline
Settled in Member
User avatar
MikeJhn wrote:
Can the Proedge sharpen planer blades?
Mike
Yes, to ensure square, there is premium adjustable square guide available to make sure the plane blade is presented to the belt accurately.
Phil
 Profile
PostPosted: 15 Jan 2018, 22:38
Offline
Moderator
User avatar
Has thanked: 95 times
Been thanked: 647 times
Sheptonphil wrote:
Mike
Phil
Phil are you refering to the 90deg. setting guide for Hand Plane Blades or something for Wide Surface Planer Blades which is I believe what Mike was enquiring about.
_________________
Chas, just a traveller on the road of time.
Bits & Pieces Gallery----Web Site----Forum Links
 Profile
PostPosted: 16 Jan 2018, 11:04
Online
Valued Contributor
Has thanked: 30 times
Been thanked: 218 times
Yes, I am asking about wide planer blades.
Mike
_________________
"Sent from my laptop using all my fingers"
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 6 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
 Similar topics   Author   Replies   Views   Last post
Lathe Knife Tool and Boring Tool Sharpening
in General Metalworking
metaler
22 Feb 2017, 09:41
Poor man's Scary sharp tool Sharpening system?
in Buying Advice | Tool Reviews
MrDavidRoberts
22
1063
06 Jun 2017, 16:15
nu-tool wood turning lathe
in Wood Turning - Lathes
pongobear
37
1159
15 Nov 2017, 11:38
Lathe newbie - looking for advice on lathe for Shaker pegs.
EdK
10
680
11 Aug 2017, 11:14
Let's see your tool boxes/tool collection
Dalejones
21 Jul 2017, 22:16
Register UKW
User Tools
UKW Local
Quickly find the nearest tool suppliers & timber merchants in your area
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
UKW Terms & Privacy
