UKWorkshop Woodworking Forums
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
Author Message
 Post subject: Re: hobbymat lathe
PostPosted: 20 Nov 2017, 21:02
Offline
Valued Contributor
Has thanked: 11 times
Been thanked: 316 times
After applying a LOT of effort with pipe grips, nothing moved.
Looks like I am going to have to make some spanners. It might even need a hammer as well. Its very obvious these havent been moved before.
DAMN!
 Profile
PostPosted: 20 Nov 2017, 21:58
Offline
Valued Contributor
Has thanked: 306 times
Been thanked: 357 times
OK, but this sounds like a tough job.
So before going any further, what does the machine sound like when it's running - at all speeds? And if you've got a DTI ("clock") how much run out is there (chuck something you KNOW is round and straight - a bit of silver steel, or at worst any old good really round bar, checked for straightness by holding up to the light against a rule)? If the lathe sounds OK, and doesn't got hot around the head stock bearing housing when running fast, and assuming the run out is reasonable, personally I MAY be inclined to leave the job well alone for a while until you're more comfortable with handling the lathe overall.
By then you'll either have found a suitable spanner/s, or, more likely perhaps, be happy with tackling making you own tooling for it.
Also (sorry if this is teaching Granny to suck eggs sunnybob) don't forget that as this is a RH thread, the 1st (outer) nut is a locking nut, so to get it undone you MUST grip the outer nut quite still - NO turning - while SLIGHTLY TIGHTENING the inner nut. If it was done properly at the factory and hasn't been touched since, you'll NEVER get it undone with just one spanner/pipe wrench/mole grip/whatever.
Good luck
AES
 Profile
PostPosted: 21 Nov 2017, 01:03
Offline
Settled in Member
Has thanked: 13 times
Been thanked: 33 times
AES wrote:
where did you find that diag JG, it's a good'un?
:D :D Thanks AES - - - it's my original! - SketchUp is so easy
_________________
http://www.crescentcomputing.co.uk
 Profile
PostPosted: 21 Nov 2017, 01:28
Offline
Settled in Member
AES wrote:
So before going any further, what does the machine sound like when it's running - at all speeds? And if you've got a DTI ("clock") how much run out is there (chuck something you KNOW is round and straight - a bit of silver steel, or at worst any old good really round bar, checked for straightness by holding up to the light against a rule)? If the lathe sounds OK, and doesn't get hot around the head stock bearing housing when running fast, and assuming the run out is reasonable, personally I MAY be inclined to leave the job well alone for a while until you're more comfortable with handling the lathe overall.
I concur with that sentiment.
AES wrote:
... this is a RH thread, the 1st (outer) nut is a locking nut, so to get it undone you MUST grip the outer nut quite still - NO turning - while SLIGHTLY TIGHTENING the inner nut. If it was done properly at the factory and hasn't been touched since, you'll NEVER get it undone with just one spanner/pipe wrench/mole grip/whatever.
I would like to know what the 'Lock Ring' - - item 26 on page 9 of the manual - - does. I can speculate that it locks the chuck/main spindle but could be wrong. If that is the case then surely with that in operation the lock nut could be unscrewed - - maybe by putting a well fitting 4.5mm dia bar in one of the holes (as long as the hole is at least 5mm deep - deeper would be better) and clouting that with a hammer!
_________________
 Profile
PostPosted: 21 Nov 2017, 05:50
Offline
Valued Contributor
when the cogs are removed and the chuck spindle is free, there is a slight rubbing from the bearings. No notching or squealing, and no discernable movement.
I'm sure the lathe would still run fine for short periods, but theres enough there to irritate me and for me to want to replace them.
That "lock ring" is merely a plastic shroud "locked" down to the headstock with a tiny slotted grub screw, to cover the back of the chuck from stuff getting wrapped up in it.
The holes are quite shallow, no more than 6 mm deep at most, but there are plastic cogs and pulley wheels all around it. I would need to strip everything out to be safe from bouncing hammer blows.
Its a stupid design to have those collars completely smooth, whats wrong with two normal nuts?
I have quite a lot going on at the moment so this is now going to have to be put back for a month or so. I'm off to the UK in 2 weeks so may just let it go till I can buy the correct spanners.
Luckily I dont have any pressing need to use the lathe just yet.
 Profile
PostPosted: 21 Nov 2017, 08:41
Offline
Valued Contributor
YOU may find SketchUp easy J-G, I do NOT! (Yup, "practice makes perfect" and all that - I get frustrated with such stuff too quickly/easily). Nice clear drawing anyway.
I didn't down load the Manual, but as J-G says, sunnybob, getting a simple bar which is a nice snug fit into one of the holes of the outer ring and then banging it with a hammer may well work.
But if you're off to UK anyway soon, buying the correct tools is an even better idea.
Welcome to the land of metalworking lathes BTW - a land of loads of frustration and puzzlement plus LOTS of satisfaction (a bit like being married really) - GREAT! :D
AES
Edit for a PS: How is the chuck held onto the nose of the main shaft sunnybob? Threaded? Bolted to an adaptor?
 Profile
PostPosted: 21 Nov 2017, 08:45
Offline
Valued Contributor
You cant just use a bar. There is no way to lock the spindle. It requires two spanners used against each other.
Even then there is nothing to rest one spanner against as you bash the other one, apart from the motor casing.
a REALLY stupid piece of engineering on an otherwise very well made lathe.
 Profile
PostPosted: 21 Nov 2017, 10:42
Offline
Settled in Member
It does look to be well engineered in many respects - particularly having twin taper roller bearings - so not having a spindle lock seems out of place. Ever seeking to circumvent deficiencies, I try to think 'outside the box' - - - - you could clamp a bar in the chuck which also extends into the gap in the bed. This would effectively 'lock' the spindle.
The plastic gears should not be taking any of the stress applied since they should be dis-engaged - surely they are only engaged when auto-feeding or screw-cutting?
6mm deep ought to be enough to provide sufficient purchase in a 4.5mm hole but I suspect that a 'tickle' with a hammer wouldn't do much - it would need a 'short sharp shock', maybe after a dose of penetrating oil ?
_________________
 Profile
PostPosted: 21 Nov 2017, 10:52
Offline
Settled in Member
I will admit that it's not the first drawing I've done - I have a fully detailed SketchUp model of my Myford S7 and a brick by brick drawing of my property :)
_________________
 Profile
PostPosted: 21 Nov 2017, 11:32
Offline
Valued Contributor
I had reached the "lock the chuck" stage, but to be honest, this has gone from a half hour job to a major inconvenience as I would have to remove all the pulleys and plastic gears just in case the hammer bounced, so it is now too far down my urgent list for a few weeks, so my lathe practice is on hold.
 Profile
PostPosted: 21 Nov 2017, 14:05
Offline
Valued Contributor
@J-G: I envy you both the Myford (I have a little Chinese "mini lathe") and the SketchUp competence.
"One day" - (maybe) :wink:
Sunnybob, in my world anyway, there's no such thing as "a half hour job". Either I reckon on a half hour and end up 3 days later, OR I reckon it'll be a really long job and it ends up "finished before I've even started"! "Welcome to my world. Won't you come on in .... " etc., etc. And all that ..... Enjoy your UK trip mate.
AES
 Profile
PostPosted: 04 Dec 2017, 19:25
Offline
Valued Contributor
User avatar
Has thanked: 53 times
Been thanked: 56 times
Just a thought.
Have you tried looking for a suspension C spanner?
My motorbikes all have suspension adjusted with C spanners.
Mick
_________________
It's better to be a little late in this life than early into the next.
 Profile
PostPosted: 04 Dec 2017, 20:10
Offline
Valued Contributor
Mick, REAL bikers use big screwdrivers and club hammers! (lol)
But no, wont work on this as the collar is too small. Its only 32 mm diameter, and the hole is only 4.5mm round and 5 mm deep. I could grind the peg down, but no way to balance two spanners that are far too big.
Must admit i think I will sell this lathe on. I'm too far into woodwork now to start collecting yet another set of tools, and this is far too small to be useful as a wood lathe.
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 3 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
 Similar topics   Author   Replies   Views   Last post
Lathe newbie - looking for advice on lathe for Shaker pegs.
in Wood Turning - Lathes
EdK
10
678
11 Aug 2017, 11:14
Lathe
in Wanted
Chris152
29 Dec 2017, 20:07
New lathe.
Hunter 001
8
519
05 Dec 2017, 15:34
Looking for a new lathe
Jasper42
4
456
16 Nov 2017, 21:46
New lathe
Alie Barnes
5
603
01 Nov 2017, 20:23
Register UKW
User Tools
UKW Local
Quickly find the nearest tool suppliers & timber merchants in your area
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
UKW Terms & Privacy
