Ed's new toolbox
Mr Ed
4 Nov 2007
Derbyshire
This is a project I've been meaning to do for years, but only just got round to it. None of the commercially available toolboxes suit very well the set of tools for joinery work in my view. I've long thought that the traditional style of joiners toolbox with the drop front is ideal and a thread some months ago on 'the other side' on this subject convinced me.
I needed a box for joinery tools for jobs on my house refurb, the occasional jobs I do for other people and the bits of snagging and finishing off that I end up doing at the end of projects at work. My travelling tool collection is mainly the stuff I started out with, chisels for example, which have since been replaced with better/flashier stuff that stays in the workshop.
My box is made in 1/2" birch ply throughout, with hand cut box joints on the corners and the panels biscuited into the carcass.
The fittings are mainly from Maplin, from the range of hardware they have for flight cases (thanks for the tip Boz)
The box is 700 X 450 X 200, which is based on the minimum needed to get it all in, with still being able to move it when full. The width allows the planes to sit and the bottom, and also the drill/impact driver and charger to fit. The ply is reinforced with a second thickness of ply where the hinges are fitted.
Chisels and screwdrivers stored in slots at the back, hammer and mallet at the left, combination square at the right. The pair of quick-grip clamps are fitted to a small fin of ply sticking down from the shelf.
Spirit level, panel saws, coping saw and LV dovetail saw (doing duty as small tenon saw here) fit on the lid. The saws are held in with a pair of wedges which firstly means that slightly differing saws can be fitted over time without changing the box, but also means 2 wedges are available for wedging doors etc. on site.
The trays contain;
1. Measuring and marking gear (left)
2. General tools - knife, pincers etc. (right)
3. Drill and screwdriver bits (underslung)
Finally a shot of everything unpacked to show what I managed to squeeze in;
In the end it took me 3 weekends and a few evenings to finish, which is a lot longer that I planned. Would have gone quicker without the box joints but I liked the look of them and they will hopefully extend the lift due to their strength.
Thanks for looking, Ed
Thats very nice ed - I'llbe lifting a few ideas from that when i build my tool storage.
how heavy is it ? - manageable in one hand ?
That's a very cool idea, love it. Noted. ;)
Very nice, Ed. :)
If you leave a space for it on your workshop wall somewhere, you could almost call it a 'Portable Tool Cabinet', with all the tools you've managed to squeeze in there! :wink:
Yep, I'll have to add it to my list as well! :D
Very nice indeed Ed...similar to the box I made in the 70's for college (mine was in pine and painted bright red) It had to be a set size to go under the benches. Surprising just how much stuff you can into one if it's organised properly. I like the castors on the bottom, lug it around for too long without them and you'll find one arm longer than the other - Rob
hi guys
full circle, things don't change much do they , the only difference from when i was an apprentice ours wear painted black in those days with your name on it usually in white , like the wheels on it though, with out as rob says one arm became longer than the other , but hey nice neat job . hc
Just got on the bathroom scales with it...35KG, so no not really manageable in one hand for any distance. The side handles and wheels are essential in my view.
Ed
The usual good work there Ed and well thought out, even down to the little wedges used to stop the saws moving around.
Are you still going to do your planes that were for your comp entry?
head clansman":8jj5vgn1 said:
hi guys
Good simple design stands the test of time and I reckon this is such an example, of something that has been honed over generations to the point where it does exactly whats needed. Why reinvent the wheel when theres no need.
The only issue with the design I see is the weight of a set of tools for joinery is really too much for one handed use, hence the side handles and wheels, other than that its the same box that scores of apprentices made. If I'd done an apprenticeship instead of spending 3 years at University I'd probably be exactly where I am now, except I'd already have the box! :lol:
Ed
PS - Be great to see pictures of other peoples boxes in this thread if anyone feels inclined to chip in....
Unable to comment in the light of impending secret santa...
Ed
hi ed
I don't have that design any more , as i think it was rob who said if you pack it all in very carefully they did get very heavy , but I do still have my old tool chest more than happy to post a pic if any one interested I 'll pop into the shop tomorrow and take some pics . hc
lovely stuff, it matches your impressively organised workshop.
I'm impressed with the box joints, after doing them by hand a few years ago, I think it will be a machine I use the next time!
DT
I wonder if a thinner stock could be used to reduce the weight. Something like 9mm mr mdf?
Its the stuff thats in it thats the heavy bit - the box itself is not too bad. I wouldn't go with less than 12mm as it would be too flexible I reckon.
Ed
Ed - I note from the main pic that you've done finger joints. In view of the weight a classic case here for dovetails on the box corners? - Rob
They are finger (or box) joints. Structurally you're right of course a dovetail would be better, but I didn't because;
1. I was worried the edges of the pins and tails would be vulnerable in plywood.
2. I am lazy
3. I thought the box joints looked a bit more workmanlike for a toolbox.
4. I thought dovetails would make assembly more tricky with the panels being biscuited on all 4 sides.
Hopefully they will be strong enough, only time will tell...
Cheers, Ed
I guess you could reinforce it with a 'pin' or dowel through the joint? It could be a 6mm length of brass rod. If you can get a long enough drill bit that is. Although you'd only need to pin the first few fingers.
Very neat. I'm a little surprised at the weight though, considering (with all due respect here) how little you have in it in terms of fixings, screws, and general odds & ends.
My standard 'go everywhere' stack weighs in at about 40Kg and seems to house a lot more - or maybe it's just 5 Kg of screws and fixings I lug around! :wink:
Anyway, very nice job, and thanks for sharing it with us.
Cheers, Pete
I have several other boxes for screws, fixings and the like, so this one was intended for just tools.
Weight-wise its more than I thought, must be the 3 planes and 2 drills that do it, plus including all the boxes and shelves its about 3/4 a sheet of ply.
Ed
