Moderators: Random Orbital Bob, nev, Charley, CHJ, Noel
 Reply
User avatar
By Osvaldd
#1321996
I'm curious what kind of flat stable material do people use with these cheap thin diamond plates.
I have glued mine on to 20mm plywood but it soaked up water and warped. not good.
User avatar
By Jacob
#1322014
Osvaldd wrote:I'm curious what kind of flat stable material do people use with these cheap thin diamond plates.
Better by far, cheaper and faster cutting, is thin paper-backed wet n dry used very wet on an impervious surface. Once flooded and well soaked it stays down flatter than cloth backed or glued down.
Good idea to keep the sheets between boards so they stay flat. For a long plane sole just use two sheets end to end. I do mine on my planer bed with white spirit.
I seem to do it most often to old chisel faces which have been slightly dubbed over by previous owner - I guess by flattening on dry sand paper. Otherwise difficult to sharpen and take off the burr.
User avatar
By AndyT
#1322015
I've got some but rarely use them, so in my case the answer is Nothing.
But if you want something more stable than plywood, then painted softwood, hardwood, tile, stone, steel - whatever you can find. Modern construction adhesive in a cartridge will stick to anything.
User avatar
By ED65
#1322027
As I've mentioned before (this thread I'm sure) I simply clamp mine down to the workbench top. Sure you lose some length but long strokes aren't vital with a diamond plate especially; you can perfectly reasonably hone across stones and plates – made all the more doable with diamonds because they're so abrasive – meaning the length becomes almost irrelevant (making the premium for long plates all the more questionable for many users).
Osvaldd wrote:I have glued mine on to 20mm plywood but it soaked up water and warped. not good.
If you're gonna use water ya gotta use a waterproof substrate. Although perhaps this indicates you're using a little too much liquid most cheaper WBP ply, as from the likes of B&Q, is not up to much.
Just to repeat: you can use diamond plates dry and they work perfectly well that way.
Unlike with stones there is no issue with glazing, the surface can't clog up badly and it's the work of moments to clean if you're doing a lot of work in one session. The swarf doesn't cling when it's dry, you can just wipe it off with kitchen paper. Or sweep off with a dirty-jobs brush, or lift it off using a strong magnet inside a plastic bag.
If it's felt necessary you can do a deep clean with a wad of kitchen paper wet with white spirit about once or twice a year, after which your plates will look virtually new again. But this is a cosmetic thing, the difference in cutting between slightly grubby looking and totally clean is unnoticeable. At least from 1,000 grit and on down.
By Rich C
#1322094
I have a couple stuck to MDF. I haven't had any warping, but they're not my main stones either.
Jacob wrote:Better by far, cheaper and faster cutting, is thin paper-backed wet n dry used very wet on an impervious surface. Once flooded and well soaked it stays down flatter than cloth backed or glued down.
I wouldn't call sandpaper cheaper, or better for that matter.
Thin diamond plates cost £3-4 each and last for months to years. Sandpaper lasts hardly any time at all, a few weeks maybe? Also, you can't tear a diamond plate if it gets snagged.
By Bedrock
#1322108
I have used the Axminster self-adhesive diamond plates for around 3 years or so, stuck to a granite tile from a local tile supplier, which is as flat as I am ever likely to need. Can't remember the cost - depends on the size, but not an arm and a leg.
User avatar
By Jacob
#1322114
Rich C wrote:.....
Yebbut how often do you need to flatten the face of a chisel (i.e. the first 10mm or so) or the sole of a plane? For me - once in the lifetime of the tool. Doesn't tear or get snagged and it is silicon carbide not any old "sand".
I wouldn't use it for routine sharpening - just remedial work. Routine: just oil stone.
User avatar
By sammy.se
#1322116
I've taken the advice on this thread re diamond plates, cheap from Alibaba.
Really happy with the result!! They cost me between £1.50 - £3 each, I bought a handful, different grits and a couple of different designs. Can't ask for much more really. They were delivered within 3 weeks.
I haven't stock them to anything yet. I have some glass plate which I previously used for the wet n dry paper method. A may epoxy them to that, but for now, I just use them on a table top.
I'll post pics at some point. I did sharpen some kitchen knives was well - hair shaving sharpness achieved !
Really happy - a super sharpening solution for £10 all in!
Just need to sort myself out a cheap stropping solution and autosol. Not got round to that yet.
Edit: got my sharpening threads mixed up. I meant to post this on ED65's thread, here:
https://r.tapatalk.com/shareLink/topic? ... source=app
Regarding ease, I will probably buy a honing guide at some point, free hand works, but I like knowing I have a consistent angle.
Sent from my SM-G973F using Tapatalk
User avatar
By AndyT
#1322119
Osvaldd wrote:I have some kitchen tiles but none are flat, there's either a hollow or a bump in them.
I wonder what is the easiest way of flattening them... :wink:
By Rich C
#1322169
Jacob wrote:Yebbut how often do you need to flatten the face of a chisel (i.e. the first 10mm or so) or the sole of a plane? For me - once in the lifetime of the tool. Doesn't tear or get snagged and it is silicon carbide not any old "sand".
You can call it whatever you like, it's still sand by another name. I'm yet to see a wet and dry paper that won't tear, especially when saturated with water.
Regardless, you can get a set of diamond plates for the cost of a pack of wet and dry and that's before we even get into buying oilstones.
Much cleaner in use too.
User avatar
By Trevanion
#1322179
Surface grinder with a diamond wheel?
:wink:
User avatar
By Ttrees
#1322189
Pain in the ar#e they are! was using the 300g today after hitting a staple.
Mostly I find them useful for reducing the camber using the corners but they keep tipping.
I have some narrow granite pieces somewhere and plenty of epoxy and a stone grinding disc for the angle grinder so must do it soon.
I like the ones bonded to the steel plates, as I only have space for two stones, this one will be a bit awkward to put away compared to an Ultex or whatever.
User avatar
By Jacob
#1322217
It doesn't tear if you do it right. White spirit, not water. Water causes rust.
Yes to messy. Copious supply of oily rags required. I use wet n dry just for remedial work , not routine sharpening, and a pack lasts for years. Typically about 25p a sheet. Two sheets 80 grit and you can flatten a no.7 sole quickly and easily - if you've got a big enough impermeable flat surface to put them on
For sharpening oilstones are cheapest option by far - they last for life.
