 Reply
User avatar
By bugbear
#972996
JimB wrote:I think the problem lies in modern-day advertising. There is so much out there being promoted as the answer to a woodworker's dreams that any real advances tend to get lost in the noise (or buried in the shavings).
I don't think it's advertising; the problem is that, at any point in time, there are many innovations, and it's not always easy to tell which are the good ones, the ones which will last.
I am reminded of this most saturday mornings, when a radio 2 show plays most of the music from the 1950's and 60's.
In hindsight, we tend to think it was a golden age, with nothing but great music.
This programs shows you the dross as well.
BugBear (who hears it in his round of the town charity shops, bargain hunting)
User avatar
By Jacob
#973002
What advances?
Most of what is talked about is retro styling - going back to thick blades, poor quality adjusters, giving meaningless steam-punk names to bits of steel (PMT-999) whatever it's called.
I can't say I'm aware of any advances over my collection of very old tools - quite the opposite - increasing cosmetics but a serious decline in quality - the steel they use on LN LV plane bodies is soft and inferior to the normal cast iron of a generation ago.
By Tony Zaffuto
#973043
Knowing way more than a bit about powder metallurgy, I have purchased a chisel and a block plane blade made from PMV-11 and find it easily delivers for the types of wood I work (cherry, walnut, white oak, and similar species). I found little time difference in achieving an edge with either my oilstones or SpdyderCo ceramics, after determining the correct bevel angle (around 25 degrees). The edges held up better than A2 (which I hate-O1 or W1 are my favorites).
Why my interest in PMV-11? To begin with, I own a powder metal parts manufacturing business and I was curious as to how the material would hold up. It is made differently than traditional powder metal (which would describe my plant) and characterizing the material as powder metal does not do it justice as the processing of the metal composite is what gives the material its uniqueness. In using the edge tools I have, I have paid close attention to see if it would show the negatives of using a traditional powder metal manufacturing method, and the PMV-11 did not exhibit any of those negatives.
I'm not sure of Rob Lee's future plans for this material, but I see uses for it far beyond the tiny hand tool market, perhaps it will be used in a larger segment of the Lee Valley business, or perhaps it is the first iteration of an evolving material. I don't know. I will say it is my belief that how it was done is certainly patentable for content and process (I hold a patent on a powder metal material where we have achieved electrical conductivity approaching 30% above traditional wrought materials, for process and material composition).
By Corneel
#973046
LV is on the application side of the material, not the development side. I guess the steel manufacturer certainly has patented this stuff. I am not sure if you can patent an application of an already patented material in this case. When you choose a knife steel and use it for plane blades and chisels, would that be patentable?
When you dig around a bit you find all kinds of wonderfull new steels. They have entire lines dedicated to knife steels for example these ones: http://sb-specialty-metals.com/products/knifesteels
LV makes it clear in their published articles that they didn't invent the steel themselves, they just investigated likely candidates.
By Tony Zaffuto
#973051
Corneel wrote:LV is on the application side of the material, not the development side. I guess the steel manufacturer certainly has patented this stuff. I am not sure if you can patent an application of an already patented material in this case. When you choose a knife steel and use it for plane blades and chisels, would that be patentable?
LV is on the application side of the material, but also could control the development, as I did. Within the PM industry, there are only a handful of raw material suppliers, and end users having an active role in development is not at all uncommon, as is the patenting of the end result. In my case, it was not a new steel, but a method of using a carrier material to permit an additive to remain within the final part. The carrier material liquifies and "burns out" of the end product, leaving the desired material within. All materials are commonly available, but the process and mixture was new. Incidentally, the use of it is for a really exotic product: solenoids and stators for electric motors.
I have no knowledge if LV did or did not patent the material or process, but does demonstrate a measurable incremental improvement over other steels. How it is accepted is up to the marketing department as well as the buying public!
By Tony Zaffuto
#973062
The interesting part lasted for about five minutes! Then it's just work.
Application is also pretty boring: shell/case for solenoids as I said, but the higher conductivity makes for a more energy efficient product for our customer. For electric motors, it is cost savings for the motor builders, as our material will permit a single stator instead of a stack of stamped stators, without any degradation of performance.
User avatar
By bugbear
#973064
In general, it is certainly possible to patent the novel and unobvious application of an existing patent to a new art.
BugBear
By JimB
#973220
bugbear wrote:I don't think it's advertising; the problem is that, at any point in time, there are many innovations, and it's not always easy to tell which are the good ones, the ones which will last.
This programs shows you the dross as well.)
I always found tool selection to be easy back then - you stuck to Stanley or Record for planes and as for other stuff, we were told made in England is good, British made probably isn't and Empire made is rubbish. :D
My mother complained about the music being vacuous but I pointed out that she grew up with such lyrics as, 'when my sugar walks down the street, all the little birdies go tweet, tweet tweet'. :roll:
