UKWorkshop Woodworking Forums
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
Author Message
PostPosted: 22 Dec 2017, 10:57
Offline
Prolific Contributor
User avatar
Has thanked: 850 times
Been thanked: 493 times
Have you priced water jet cutting?
That would cut brass, tufnol, nylon, steel, and can be very accurate.
I have NO IDEA on the cost.
BugBear
_________________
...a sharp tongue is the only edge-tool that grows keener by constant use.
-- Washington Irving
 Profile
PostPosted: 22 Dec 2017, 15:27
Offline
Settled in Member
Has thanked: 13 times
Been thanked: 33 times
Deadeye wrote:
Hi
Yes - I do have a smallish drill press and a 4" vice. I think I can do the bores pretty accurately. The issue is the teeth
If I could buy blanks with the right numbers of teeth I'd be sorted.
If you can take pre-cut gears with just a mark to indicate the centre and drill them on a drill-press with the accuracy of 0.01mm "you're a better man than I Gunga-Din" !!
MOD 1 gear teeth are only 2.4mm deep so if you are (say) 0.1mm out of centre with your bore you'll get less than a quarter turn before binding - unless of course you increase the nominal centre distance between meshing gears by (say) 0.4mm and that would lead to 'sloppy' mesh for most of each turn. Not only that there would be a sinusoidal variation in the speed of the driven gear.
It may well be acceptable (though inaccurate) for your application if it involves only forward motion (ie. clock or Orrery) but normally the bore and PCD should be absolutely concentric - and that is difficult to achieve without cutting the bore first.
You could use straight sided teeth and 'lantern' pinions which would negate all issues about bore concentricity and accurate centre distance of course!
_________________
http://www.crescentcomputing.co.uk
 Profile
PostPosted: 22 Dec 2017, 16:11
Offline
Settled in Member
Has thanked: 1 time
Been thanked: 12 times
Being as I live across the pond I added England to a search "plastic gears" and got the following.
http://www.hpcgears.com
https://www.bearingboys.co.uk/Plastic-- ... ars-3314-c
https://www.gearsandsprockets.co.uk
http://www.motionco.co.uk/gears-c-32.html
Plus what comes up on eBay, Amazon and Aliexpress.
I also had a quick look on Alibaba.com and tons of companies have plastic gears of all sizes with many having the MOQ starting with one part. If you know the gears sizes and specs you can provide them with a list of them with the quantities you want and they will come back to you with a price and shipping options. I've done the same buying LED lighting for my workshop and a VDF to run a 3phase dust collector.
Once you get the gears from any of these places you will only need to put them on your machine and not have to futz with the bores.
 Profile
PostPosted: 22 Dec 2017, 17:48
Offline
Participant
Has thanked: 22 times
Been thanked: 0 time
Hi
I can centre by getting a pin the right size in the chuck and then clamping the gear whilst changing to a bit of the target bore diameter. A little "slop" isn't the end of the world.
I have found loads of sites that sell gears of the right sizes - at £5-25 per gear it's going to cost me hundreds of pounds for a proof of concept project!
I looked at water jet cutting. In terms of cost/cm, approximately it seems: water jet >> CNC > 3D print > laser >> moulding > cut your own (ignoring time).
People seem not to build much geared stuff these days!
 Profile
PostPosted: 22 Dec 2017, 18:07
Offline
Settled in Member
Has thanked: 1 time
If you had written in your first post the steps you had already taken and the conclusion you've come to I would not have spent any time searching for possible sources and I suspect some others might not have either. Maybe if you have been good Santa will put them under the tree for you.
 Profile
PostPosted: 22 Dec 2017, 19:06
Offline
Participant
Golly! Sorry to have offended you; unintended.
I'm genuinely exploring the options and all the posts have been helpful in that. I hadn't looked at water jet, but now have (as a consequence of this thread) - and it's expensive.
To summarise:
- I'd like to do this as inexpensively as possible because, well, because.
- I tried laser cutting. It produced a technical issue, although I'm not sure whether this is a feature of lasering meltable material or poor operation
- CNC is expensive
- I have researched (following this thread) 3d printing (£1 for 8cc seems the best I can find so quite costly) and water jet (expensive)
- The ready made options are frustrating as they either have bores too wide or limited size range or cost ten quid a go.
- I can cut wood ones, but they need to be modulus 3 and up really and it makes it very big.
Sometimes on things you don't know about, someone has a great tip or insight, or a website that is perfect but is on page 20+ of the search results.
On your post specifically I have not come across Alibaba before ... and have now raised a query. It's rather a daunting site though!
Thanks again for your help.
 Profile
PostPosted: 22 Dec 2017, 23:36
Offline
Settled in Member
Has thanked: 5 times
Been thanked: 55 times
Could you buy the gears with the oversize bore and bush them down to your desired bore? Brass tube is available in 1mm increments with each size fitting inside the other. A little slop, but not too bad.
 Profile
PostPosted: 23 Dec 2017, 00:09
Offline
Valued Contributor
Has thanked: 306 times
Been thanked: 357 times
Exactly the same thought occurred to me profchris (but I remembered it after I posted on this thread). :D
AES
 Profile
PostPosted: 23 Dec 2017, 10:03
Offline
Participant
That's a good idea - thank you
 Profile
PostPosted: 30 Dec 2017, 09:36
Offline
Settling In
Has thanked: 6 times
Been thanked: 22 times
You may find that somewhere like 3D Hubs enables you to find a more competitive 3D-Printing service. You do have to register with them, but they enable you to pick the elements which are important to you for your job and match you with folks who have the capability.
I ended up matched to a local teenager with a 3D-Printer and the time to run a job for a very competitive price. You will need a 3D model of your gears though.
 Profile
PostPosted: 30 Dec 2017, 22:29
Offline
Valued Contributor
Has thanked: 47 times
Been thanked: 139 times
Thinking along the same lines, there is a place in Aberdeen called Make, which is community focused and has all sorts of printers and similar kit available for use. There are certainly other branches in Mainland Europe, so may be also elsewhere in UK.
_________________
Dick M
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 2 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
 Similar topics   Author   Replies   Views   Last post
Perforated plastic sheet - any ideas ?
in General Chat (Off-Topic)
Blockplane
3
410
11 Sep 2017, 11:40
Sheet metal bending rolls
in Wanted
leadhead66
04 Jan 2018, 09:38
Cutting 2mm thick Alloy Sheet
in General Metalworking
Claymore
18
774
08 Oct 2017, 18:44
Cogs & Gears
Rhyolith
1
428
21 Apr 2017, 14:58
Free Sheet Materials
in General Woodworking
nathandavies
9
893
17 Feb 2017, 13:48
Register UKW
User Tools
UKW Local
Quickly find the nearest tool suppliers & timber merchants in your area
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
UKW Terms & Privacy
