Conversion To Variable Speed
Gill
3 Sep 2003
Lincs
I have a single speed scroll saw that I would like to convert to a variable speed. Is it possible, and how would I go about it?
Gill
Hi Gill,
Yes it is possible but will need some research.
Two methods are available.
1. use a series (brushes) motor and control it with a speed controller (like a sewing machine.) (most likely possibility from second user parts)
2. Fit a 230 volt 3ph motor and use an invertor to supply it. (expensive)
The machine may currently have a series motor, if so all that is required is an electronic speed controller with a power rating to suit. (old variable speed vacuum cleaner for instance or the spares for such)
Major things to find out if motor needs changing,
1. physical size of motor to be replaced and its power ratings.
2. the output shaft diameter and length (to take existing fittings).
Another way would be to research the spares situation for an existing variable speed scrollsaw of similar size and see if its motor, and or controller, would be suitable.
Thanks for the advice, Chas. I've no idea how these sorts of things work and I had been hoping it would be possible to buy some sort of adapter from Maplins.
The fact that Hegner's website says it is not possible to add variable speed to their saws later because of the need to replace the motor did give me pause, so I thought I'd raise the point here. Could it be that motors which work with a variable speed unit are built differently to those with a single speed?
Gill
I do not know the answer to this, but would advise against installing a dimmer switch if for no other reason than a lighting circuit is designated 6 amps max rating and the saw will be on a 13 amp plug and fuse. Sticking an in line dimmer switch in means the switch will go first, not the fuse.
Steve.
Gill
Gill, It may be that Hegner use an invertor and a 3phase motor for their variable speed, given the price point it could well be, need to check their specs.
The main difference with an electronic speed controller for a series motor than a simple dimmer unit is that a motor control will have a feedback circuit to address the back emf of the motor and compensate for it to provide a better power output.
Not rocket science, and if you can provide details of motor type and rating fitted to your saw ,and it is a series motor (brushes) I may be able to provide a circuit diagram for a suitable controller.
There is one I made about 40+ years ago currently in my shed controlling the heaters in the parrots pen. (made in the days before electric drills etc. came with variable speeds.)
Hi Chas
Thanks for the offer but even if it isn't rocket science, it's all a bit too advanced for me. It's not as if I need a new variable speed unit added to my Hegner 1. I just thought it might be worth doing if it was only a matter of buying a component (or two) and plugging it in.
Gill
Gill":3jotvck0 said:
Hi Chas
Gill
I checked the specs. and Hegners have induction motors.
This would mean fitting a new 230V 3 Ph Motor and invertor for variable speed, Or a DC motor, (similar to that fitted to treadmills)
EDIT: looking at the Axminster Clone of the Hegner and the smaller variable speed unit it would appear that they might be using DC motors in Both.
Although the specs refer to induction motors in one breath and DC motors in another.
I had assumed it was one of the Others you were thinking of modifying.
