 Reply
By TFrench
#1281464
Yep, we ground a pretty decent vee, and managed to get about 1" in from each end on the inside. I'm pretty hopeful! First time using the Tig braze, I've done it with cast rods with a stick welder before. Key seems to be getting it all good and warm before you start.
Sent from my SM-G950F using Tapatalk
User avatar
By toolsntat
#1281472
Good work Tom,
Having never done anything like this my mechanical thinking asks a question.
If an oversized hole was bored at intervals following the break shortways when clamped together, would extra welding/ brazing be able to fill these holes all the way through?
My thinking is that this would increase the weld surface.
Cheers Andy
By TFrench
#1281613
The hard part would be getting the holes to fill up from the back - you have to get the rod and the tungsten tip in there at the same time. I did consider drilling and tapping it together with grub screws as well but for one its such a hard shape to clamp, being an open sided tube and two the crack ran in a spiral so would have needed a new setup each time. I used the die grinder and a carbide burr to remove the excess braze on the inside of the casting and got it fitted to the fence. Just need to find the right size tap for the clamp now.
By TFrench
#1281754
So far, its looking promising. Ground out the internal braze and got it fitted back on the fence rail:
ImageSuccess
I tapped the main locking screw thread back good again - the crack runs right throught the centre of the thread so if the tap didnt burst it apart it seems to be held pretty well. All that is left on this part is the grub screw that holds the pointer for the scale needs re-tapping and installing.
I've done a bit of messing around with lathes but very little "proper" work - today I turned a new pin that had been bent in the fence assembly. Surface finish is pants but I hit the sizes I was aiming for (more by luck than judgement!)
ImageTurned pin
I'm now down to 2 broken parts - the bristol lever that locks the fence is snapped and the fine adjustment clamp is broken:
ImageNext part
I think the game plan for this is to mill it off square so I can grub screw and braze a replacement section on and machine back to the correct shape. I'm really enjoying this project - it's really pushing me into trying lots of new things!
User avatar
By Trevanion
#1281757
People will really break anything, won't they! It makes me sad seeing old iron being wrecked.
On the other hand, I'm very happy you've taken on the very difficult task of putting it all back together! Kudos!
User avatar
By Trevanion
#1281772
TFrench wrote:One word: Farmers.
That's all you had to say! :lol:
By TFrench
#1284619
More progress on the saw repairs. Next up was the bristol lever that had had the thread sheared in the fall. I took it apart and couldn't get the remaining stub of thread out, so I chucked it in a collet chuck, faced it and tapped it, then did the same with a bit of whitworth threaded rod and grub screwed them together with threadlock.
ImageTapping
ImageBoth ends tapped
ImageBack together
Have to say, I'm pretty satisfied with the result!
I've also remade the knurled knub for the fine adjustment fence clamp. First attempt at parting off and by god it looks horrendous :lol: I'll put that to the inside so it can't be seen. I'll weld the knurled bit to the thread to finish it.
ImageKnurling
I only got the one photo but I've also repaired the last cracked casting - put it in the mill and squared the broken bit up, then found a bit of thickwall pipe that was pretty much the right size, cut a section out and welded to the casting with dissimilar rods.
ImageMilling flat
Just leaves painting it all now.
By TFrench
#1284766
I moved my big bandsaw home months ago and I've finally gotten round to getting it up and running :oops: I'd been putting it off as the wadkin lathe was a bit traumatic! This one was much easier, helped having the wadkin there to copy the wiring. While it was still at work I started making some cam-action castor brackets for it so I could move it but drop it down to stabilise it for use. Ended up not really working out how I wanted so I got angry and blasted some big C section brackets on with the mig welder. It's actually very stable on just the wheels, I can also wind down the corner pads if I need more stability.
Here's the inverter, with some very neat for me wiring:
ImageInverter
I found a mitre fence attachment on ebay - they are unusual as you set the angle, then a hook pulls the work through. Its all a bit of a bodge to work around the way the table splits. I'll get a better pic to illustrate my ramblings. Anyway, I needed to make something to hold all the bits and this is what I came up with:
ImageTool rack
And here it is, all finished up.
[url=https://flic.kr/p/2fXpjgt]Image
By TFrench
#1285236
Here's the mitre attachment in use:
ImageStartrite mitre guide
It's the only one I've seen for a startrite. Because the table has no mitre slot this is what they came up with - it actually works pretty well.
This evening I also finished painting and assembling the fence for the evenwood saw. All thats left to do to it is tap one grub screw hole to hold the pointer for the scale then its job done. Pleased with how this has turned out as it was basically scrap when I bought it.
ImageFinished fence
ImageFinished fence
User avatar
By Farmer Giles
#1285317
Lovely work there, fixing cast iron can be a right pig :)
I use synthetic enamel AKA tractor paint too. Odds and sods I brush on but if I'm into a project I use 3M PPS (paint preparation system) which is a series of plastic measuring cups with liners including paint filters that fit via an adapter to the spray gun replacing the normal cup.
Much less washing as you can take the cup off and put a cap on it and it will stay fresh for days so you can mix a full cup. You can then swap it for one with gun wash in it, job done. I don't like single use plastics but this saves paint/thinners so overall is beneficial and takes all the hassle out of spraying, plus the liners are pretty thin, not a lot of plastic in them. I tend to just use one liner per type of paint per project.
Andy
