Will Dutson
- Joined
- 13 Aug 2023
- Messages
- 11
- Reaction score
- 6
I'm cladding a timber frame workshop/garden room with 150mm feather edge. What screws would you recommend for fixing 25mm thick vertical battens onto 11mm osb and 4x2 studs?
Thanks, do you remember what size you used?When doing a similar job I chose some Forgefast exterior, probably decking, screws from toolstation.
Their elementech 2000 coating claims to pass a 2000 hour salt spray test which is relatively demanding. Tan or green options not that it mattered.
I like torx head screws so that also worked for me.
Spax are also very good but £££
To me it's worth paying a bit more for good fixings if you are building something to last. It's pretty tedious replacing rotten screws in something that is otherwise perfectly sound.
Absolutely. I've wrung the head off about 6 of the first dozen I used screwing down chipboard last week. No reason to be using ss but it was the first thing to hand.be careful if u use long st/steel screws...they are quite soft and easily snap........
I recently had to fix some tiles on my roof and a few had the original galv nails in from the mid 50's. Still as good as the day they were hammered in.Personally, I'd just use 65mm galvanised nails - much cheaper, much quicker and will outlast you and your kids - many thousands of roofs have used them and are still going strong after 6o years or more.
