Avoid the Woodstar BS52 like the plague.
I bought one from Machine Mart and it took them three weeks to get the correct collets to me because it was supplied with 8mm and 12mm collets instead of the UK 1/4" and 1/2".
I bought it just to keep in one corner of the workshop for putting light mouldings on bead. It seemed fine on the trial run, but when I put through four lengths of 760mm long 15 x 15 bead material the ogee cutters DROPPED by 2 mm. The vibration overcame the locking action on the height adjustment, which was as tight as it would go.
And the dust extraction outlet has guard bars across it which clog up with swarf in about one second flat. I cut them off, which I suspect Machine Mart will use as an excuse not to refund the whole amount.
The machine was returned to Machine Mart two weeks ago for refund. Still haven't heard from them.
