| Author |
Message |
echotitan
Posted: 18 Mar 2010, 19:53 |
| Forum Newbie |
Joined: 18 Mar 2010, 19:43 Posts: 4 Location: wales Has thanked: 0 time Been thanked: 0 time
Hi everyone
I'm looking for supplier of wood slices / tree discs with the bark intact to make house signs with. I'm struggling to find anywhere that caters for this and don't think other sign makers would like to tell me where they are getting their supplies.
any help would be appreciated.
cheers Echo
| Top |
SNight
Posted: 18 Mar 2010, 19:55 |
| Settling In |
Joined: 11 Nov 2009, 16:21 Posts: 117 Location: Lancashire Has thanked: 0 time Been thanked: 0 time
Any good local Timber merchants should be able to supply you with waney edge boards. Hope this helps.
| Top |
jasonB
Posted: 18 Mar 2010, 20:00 |
| Valued Contributor |
Joined: 26 Nov 2004, 19:04 Posts: 4918 Location: Surrey Has thanked: 0 time Been thanked: 8 times
house signs usually have the bark al round and are cut at about 45deg to the trunk. Try asking a sawmill or tree surgeons who will be able to slice up some small trunks or branchwood.
Your biggest problems will be stopping the disc cracking and keeping the bark on as the wood dries out.
Jason
_________________ Don't waste wood, it doesn't grow on trees you know!
| Top |
Mattty
| A Regular Member |
Joined: 09 Oct 2008, 14:31 Posts: 1075 Location: Leeds Has thanked: 0 time Been thanked: 7 times
I'd have thought a medium sized bandsaw and and a couple of logs and you could make them very cheaply. From what i remember they are diagonal slices of logs around 5-6" diameter?
| Top |
Mattty
| A Regular Member |
echotitan wrote: Hi everyone
cheers Echo
Quoted to show the link-
Edit- Link removed!
| Top |
echotitan
Posted: 18 Mar 2010, 20:22 |
| Forum Newbie |
Mattty wrote: I'd have thought a medium sized bandsaw and and a couple of logs and you could make them very cheaply. From what i remember they are diagonal slices of logs around 5-6" diameter?
Yes, I would be looking for 6-10 inch in diameter, and dryin them is a pain, I already cut them with a chainsaw, but if the business takes of i'll need a more regular supply.
| Top |
Mattty
Posted: 18 Mar 2010, 20:25 |
| A Regular Member |
echotitan wrote: Mattty wrote: I'd have thought a medium sized bandsaw and and a couple of logs and you could make them very cheaply. From what i remember they are diagonal slices of logs around 5-6" diameter? Yes, I would be looking for 6-10 inch in diameter, and dryin them is a pain, I already cut them with a chainsaw, but if the business takes of i'll need a more regular supply.
Buy a decent sized bandsaw and get cutting them. They should dry quite quickly due to the amount of end grain exposure- how you stop them cracking though i have no idea.
| Top |
Mattty
Posted: 18 Mar 2010, 20:26 |
| A Regular Member |
Post the link to your web site again
| Top |
echotitan
Posted: 18 Mar 2010, 20:43 |
| Forum Newbie |
| Top |
Mattty
Posted: 18 Mar 2010, 21:17 |
| A Regular Member |
I think they are lovely mate. The paintings are really pretty.
| Top |
wizer
Posted: 18 Mar 2010, 21:32 |
| Professional Mutterer |
Joined: 03 Mar 2005, 13:15 Posts: 15589 Location: Creating and Fixing C*ckups Nr Dartford, Kent. Has thanked: 0 time Been thanked: 0 time
I very much doubt that you will find an actual supplier of these. You might find a tree surgeon or small saw mill that might be able to do them for you on special order, but would someone actually have them as a stock item? I doubt it. As others have said, the best way in the long run will be to cut them yourself with wood bought or scrounged from tree surgeons.
| Top |
L Harding
Posted: 18 Mar 2010, 21:39 |
| Settling In |
Joined: 19 Nov 2009, 17:01 Posts: 188 Has thanked: 0 time Been thanked: 0 time
Try 'interesting timber's' (west country way), theyve been very helpful to some odd wood requests  of mine in the past
| Top |
big soft moose
Posted: 18 Mar 2010, 22:08 |
Joined: 22 May 2008, 21:39 Posts: 5079 Has thanked: 0 time Been thanked: 0 time
Mattty wrote: echotitan wrote: Mattty wrote: I'd have thought a medium sized bandsaw and and a couple of logs and you could make them very cheaply. From what i remember they are diagonal slices of logs around 5-6" diameter? Yes, I would be looking for 6-10 inch in diameter, and dryin them is a pain, I already cut them with a chainsaw, but if the business takes of i'll need a more regular supply. Buy a decent sized bandsaw and get cutting them. They should dry quite quickly due to the amount of end grain exposure- how you stop them cracking though i have no idea.
the key to not cracking is not to dry them too far - they are going to be in an outside environment after all so they'll be fine if you dont store them in a heated environment - also several coats of clear varnish helps slow the water loss.
by the way all though the others are right about the bandsaw do be careful - you need to build a sled for cutting round things on the bandsaw as if the log rolls whiole its being cut it will jam and potentially buckle the blade
_________________ Real men don't read the instructions After all they are only the manufacturers opinion of how the produict is to be used.
| Top |
Mattty
Posted: 19 Mar 2010, 12:49 |
| A Regular Member |
big soft moose wrote: Mattty wrote: echotitan wrote: Mattty wrote: I'd have thought a medium sized bandsaw and and a couple of logs and you could make them very cheaply. From what i remember they are diagonal slices of logs around 5-6" diameter? Yes, I would be looking for 6-10 inch in diameter, and dryin them is a pain, I already cut them with a chainsaw, but if the business takes of i'll need a more regular supply. Buy a decent sized bandsaw and get cutting them. They should dry quite quickly due to the amount of end grain exposure- how you stop them cracking though i have no idea. the key to not cracking is not to dry them too far - they are going to be in an outside environment after all so they'll be fine if you dont store them in a heated environment - also several coats of clear varnish helps slow the water loss.
I have a pretty good understanding of timber technology- not to the extent of Richard Jones but still ok.
Whilst i agree that slowing the rate of drying is important and there would be little point in drying these to a low moisture content, the fast remains that the op is trying to dry a slice of log, which in it's very nature is nearly impossible to do due to how timber shrinks.
All timber when drying shrinks along the length of the annular rings and thus if the timber in question is a slice from the end of a log the outer rings are shrinking much more than the inner rings thus the slice will split. This splitting can be reduced using various techniques and if the slices are very thin (such as oyster veneers) then the timber can be stabilised.
If the slice is at an angle say 45 degrees rather than 90 degrees then the splitting whilst drying is greatly reduced, and this is the type of wooden external sign that i have commonly seen.
You are correct about cutting logs on a bandsaw, they can easily twist and wreck the blade, this is easily solved by cutting the log in a cradle or other similar holding device.
| Top |
Doug B
Posted: 19 Mar 2010, 20:10 |
| Regular Contributor |
Joined: 06 Aug 2008, 19:09 Posts: 1679 Location: Notts Has thanked: 0 time Been thanked: 1 time
I`d go for PVA as a sealer to slow the drying process rather than varnish.
I use PVA as an end grain sealer for all my planked boards & turning blanks, the added bonus in this case is that a couple of coats applied copiously will aid in keeping the bark attached during the drying process.
_________________ Alcohol does not solve any problem.......................then again neither does milk  .....  ....
| Top |
Who is online |
Users browsing this forum: custard, yetloh and 4 guests |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
Quickly find the nearest tool suppliers & timber merchants in your area
