| Author |
Message |
Chems
Posted: 29 Oct 2010, 00:35 |
| Valued Contributor |
Joined: 23 Apr 2008, 00:01 Posts: 4066 Location: A Wood Haven Has thanked: 7 times Been thanked: 8 times
Fitting a window sill?
I've got the odd job this weekend to fit an oak windows sill. What's the lay of the land on this, its oak and wants to be hole less really, but don't want to glue it down if you guys think it wont hold. A proper job needs to take place, as its for my dad! The last one bowed up an broke away from the plaster beneath, but that was the window fitters fault/builder as no expansion room was left.
TIA
| Top |
cgw59
Posted: 29 Oct 2010, 03:33 |
| Forum Newbie |
Joined: 10 Aug 2010, 13:37 Posts: 18 Location: N.Ireland Has thanked: 0 time Been thanked: 0 time
Hi , I assume it's an indoor sill board that you have to fit , if it is a method that I have used successfully in the past is to screw heavy gauge 35 - 40mm brass screws to the underside of the board , then drill holes into the masonry surface that it will sit on and fill them with either a thin mix of rapid set cement or epoxy putty, then push the screws fitted on the underside of the board down into the mix nd set some weights on it until it has hardened. Some beads of adhesive on the underside will add grip to the whole area and this method will leave not signs of how the board has been fitted. hope you get the idea and find it a help.
| Top |
devonwoody
Posted: 29 Oct 2010, 06:30 |
| Respected Contributor |
Joined: 11 Apr 2004, 08:35 Posts: 11275 Location: Paignton Devon Has thanked: 33 times Been thanked: 32 times
When mine where fitted 20 years ago long screws and plugs were placed in the top screw holes. Timber was left bare with just a sanding sealer and have never moved. Must depend on the timber quality I suppose.
| Top |
AndyT
Posted: 29 Oct 2010, 08:43 |
Joined: 24 Jul 2007, 16:32 Posts: 3396 Location: Bristol Has thanked: 22 times Been thanked: 63 times
Maybe worth mentioning that good practice is to run a tongue along the edge of the window board to fit into a groove ploughed across the bottom horizontal part of the window frame. So it's worth extracting the old one first, and if it has a tongue on it, copy that on the replacement.
_________________ Andy
| Top |
jasonB
Posted: 29 Oct 2010, 15:44 |
Joined: 26 Nov 2004, 19:04 Posts: 4918 Location: Surrey Has thanked: 0 time Been thanked: 8 times
Get some bat straps with a bend in them, screw to underside of window board and chase out plaster so they can be screwed to the masonary and then filled. The straps will hold them down and also stop any tendancy for the board to cup.
You can also put a load of screws into the underside and set the board on an inch or so of drywall adhesive.
Jason
_________________ Don't waste wood, it doesn't grow on trees you know!
| Top |
johnf
Posted: 29 Oct 2010, 20:37 |
| Settled in Member |
Joined: 16 Jul 2008, 20:41 Posts: 550 Location: Sunny Sussex Has thanked: 0 time Been thanked: 1 time
jasonB wrote: Get some bat straps with a bend in them, screw to underside of window board and chase out plaster so they can be screwed to the masonary and then filled. The straps will hold them down and also stop any tendancy for the board to cup.
Jason
Thats how hundreds of thousands of window boards have been fixed on building sites everwhere
_________________ John
Recyling Wood
| Top |
chippy1970
Posted: 29 Oct 2010, 21:50 |
Joined: 03 Jun 2007, 15:10 Posts: 2052 Location: London Has thanked: 2 times Been thanked: 14 times
Window boards on the inside NOT sills
Anyway we normally fix MDF ones with expanding foam but for your oak ones i would be tempted to strap them down as said above.
| Top |
Chems
Posted: 29 Oct 2010, 23:01 |
Thanks,
The window is PVC.
Tempted to go the easy use with some DryWall adhesive.
Not 100% sure on what the bat strap method is.
Do you mean mount the straps along the short length, as in coming off the window at a tangent, not inline across the window?
| Top |
jasonB
Posted: 30 Oct 2010, 07:06 |
They are an L shaped bar that has holes all along its length like this
The short leg of the L is screwed to the underside of the window board, the long leg extends down the wall 2ft or so and is screwed to teh masonary and subsequently plastered over or you can chase out the plaster, fix and then fill the channel.
| Top |
chippy1970
Posted: 30 Oct 2010, 10:09 |
Chems wrote: Thanks,
The window is PVC.
I wouldnt use Drywall adhesive its very wet you want to avoid moisture near a timber board un less you are sealing them fully before you are fitting them. You would bet better off using expanding foam or try the newer dot and dab foam if you dont strap them down make sure you weight them down or the foam wil lift the boards.
| Top |
liam8223
Posted: 30 Oct 2010, 19:38 |
| Settling In |
Joined: 01 Dec 2009, 21:32 Posts: 103 Location: Leicester, UK Has thanked: 0 time Been thanked: 0 time
Only my recent experience, but i have dropped my solid oak window boards (made by me) directly into the aperture and they haven't moved a bit. been there nearly 8 months so had plenty of temp and humidity changes.
Took it back out today to fix it down, just going to evo grip it to the plasterboard, in the same vein as using grip to fix skirting, should be more than strong enough.
Am i Wrong?
| Top |
Chems
Posted: 01 Nov 2010, 15:23 |
Well Karl was over early on saturday morning so asked his advice and had a look at it. He said to seal it fully an stick it down. So we did. Finished article:  If I'd chosen the piece I'd have probably not got a character piece and instead got a prime piece with no knots, buts its all characters. Used a 2 part epoxy to stabilise and fill them.
| Top |
liam8223
Posted: 01 Nov 2010, 16:31 |
| Settling In |
looks spot on to me, mine ar alot thicker tho, 32mm.
got a bit over keen when ordering the AW oak!
| Top |
Chems
Posted: 01 Nov 2010, 16:32 |
Well these were about 20mm I think, had to match the size of the ones that came out.
Forgot to say, used No Nails to stick it down, after sealing both sides with a few coats of danish oil.
| Top |
chippy1970
Posted: 01 Nov 2010, 18:09 |
Chems wrote: Well these were about 20mm I think, had to match the size of the ones that came out.
hope that wasnt solvent free no nails its rubbish we have stopped using the yellow solvent free gripfil now on new builds a lot of the skirtings etc have popped off the glue doesnt bond very well with the plaster walls. The newer mastic type glues "sticks like s**t" and that type are great if a little expensive.
| Top |
Who is online |
Users browsing this forum: BECKS and 5 guests |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
Quickly find the nearest tool suppliers & timber merchants in your area
