UKWorkshop Woodworking Forums
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
Author Message
PostPosted: 29 Apr 2010, 08:19
Offline
A Regular Member
User avatar
Has thanked: 2 times
Been thanked: 1 time
I need to buy a decent 1/4 sheet palm sander and would be interested to hear what peoples experience is with them. I'd be particularly interested to know if those who have the festool think it worth 3 - 4 times as much as the others. I'm tending towards the metabo as I have their SXE 425 ROS or the makita - the bosch looks to have too many plastic bits to fall off .
Cheers,
Steve
_________________
'Personally I'm always ready to learn, although I don't always like being taught' - Winston Churchill
Share on Facebook Share on Twitter Share on Digg
 Profile
 Post subject:
PostPosted: 29 Apr 2010, 09:12
Offline
Location: Creating and Fixing C*ckups Nr Dartford, Kent.
Has thanked: 0 time
Been thanked: 3 times
I have the older DeWalt model and I honestly can't fault it. It's my favourite electric sander, light and easy to handle.
 Profile
 Post subject:
PostPosted: 29 Apr 2010, 09:26
Offline
Settling In
Has thanked: 0 time
Been thanked: 0 time
i have the bosch and the hitachi cant fault the bosch, hate the hitachi but keep it as a spare (just in case lol)
 Profile
 Post subject:
PostPosted: 29 Apr 2010, 09:48
Offline
Valued Contributor
User avatar
Has thanked: 15 times
Been thanked: 10 times
I have the Festool, with electronic speed control.
It's light, quiet, powerful, has little vibration and very comfortable to use.
It sands very well and works a treat with a Festool vacuum attached.
I didn't try cheaper sanders though because I like Festool.
Only you can decide whether it's worth the money.
It's replaced a Skil palm sander which I find noisy and unpleasant to use (yours for £10+p&p :) )
_________________
Cheers,
 Profile
 Post subject:
PostPosted: 29 Apr 2010, 09:51
Offline
Settling In
Has thanked: 0 time
Festool every time
Woodguy
 Profile
 Post subject:
PostPosted: 29 Apr 2010, 10:53
Offline
Prolific Contributor
User avatar
Has thanked: 0 time
Same here...nice little sander. You can get hold of a little adaptor that allows it to be plugged into your 'shop vac which makes it even better - Rob
_________________
The Blokeblog
 Profile
 Post subject:
PostPosted: 29 Apr 2010, 11:08
Offline
Settled in Member
User avatar
Has thanked: 0 time
Another vote for the Dewalt here.
Solid, light weight, vibration free, not that noisy, comes with a long cable and reasonably priced.
I looked at the Metabo, Makita and Bosch but went for the Dewalt because I could plug my shop-vac straight in with no other mods.
The Festools is probably better than all the others, but so it should be :shock:
Mark
 Profile
 Post subject:
PostPosted: 29 Apr 2010, 12:08
Offline
Regular Contributor
Has thanked: 25 times
Been thanked: 132 times
+1 for festool. Small, lightweight, quiet, low-vibration, 4m cable as standard and you can run them all day, every day - haven't killed one yet ;)
Couple of things to be aware of; the Festool pad is 80x130mm, whereas the DeWalt is a 'squarer' quarter-sheet (115 x 140??). Festool has a 2mm stroke, vs DeWalt 1.4mm, so will be a little more aggressive in comparison (caveat - according to the specs; haven't done a comparison as I don't own the DeWalt). And remember that Festool has a proprietary hole pattern, so you need to buy their abrasives or use something like Abranet.
HTH Pete.
edited for clarity
_________________
carpentry, cabinets, kitchens & bathrooms
http://www.petermillard.com
YouTube
 Profile
 Post subject:
PostPosted: 29 Apr 2010, 14:30
Offline
Valued Contributor
User avatar
Has thanked: 20 times
Been thanked: 9 times
Another one for the Dewalt. Great little machine that comes with its own punch, so that you can buy the big rolls of sandpaper and punch the holes in exactly the right place. Beats paying mega bucks for pre punched 5 to a packet sheets.
Mike
_________________
Looking for a book or plan?, then drop in below and have a browse. When you have finished why not help other members by leaving a link we do not already have.
free-downloadable-woodworking-books-plans-ref-sites-t82220.html
 Profile
 Post subject:
PostPosted: 29 Apr 2010, 15:22
Offline
Participant
Has thanked: 0 time
The DeWalt one is great now, although it never used to be that good.
Bosch one, clips are slightly dodgy on the front. I think they have repaired this problem now however.
Makita is absolutly fantastic and I would reccomend it a lot. Not had any experience with the Metabo or Festool. Although Metabo is 3 year warranty so that may swing you!
 Profile
 Post subject:
PostPosted: 29 Apr 2010, 16:20
Offline
Settled in Member
User avatar
Has thanked: 0 time
I've had the Bosch for a couple of years and like it - particularly the fixing method which means you can use sandpaper cut from a roll. It comes with a plastic doodah to perforate the sheet once mounted. No vac connection but I think I'd find that a PITA anyway as the sander is a 'go anywhere'. Does have a fairly ifficient built in dust collector.
 Profile
PostPosted: 29 Apr 2010, 17:57
Offline
Valued Contributor
User avatar
Has thanked: 0 time
Been thanked: 2 times
promhandicam wrote:
I...the bosch looks to have too many plastic bits to fall off .
Well, you're certainly not wrong there (in my experience)! :D
I bought the Bosch one just over a year ago and, on its second day of use, the front clamp just broke off while I was sanding :x (that explained why the paper kept working lose at the front!). It is lightweight but, compared to their 5in ROS (which I love! 8)), it is noisy and does vibrate quite a bit. You also have to buy an additional adapter if you want to hook up a vacuum. :P
On the rare occasion that I've wanted to use it since buying the small ROS, I've managed to use velcro-backed sheets without any trouble at all. I should probably try and sell it, really. Or, at least get it repaired while it's still under warranty...
_________________
Olly.
My Blog
YouTube Channel
 Profile
 Post subject:
PostPosted: 29 Apr 2010, 18:06
Offline
Settled in Member
User avatar
Has thanked: 0 time
Been thanked: 4 times
that reminds me..
I still have a to pay for and collect a dewalt one from Doug :oops:
JH
_________________
http://john-henrybigleyfurniture.blogspot.com/
 Profile
PostPosted: 29 Apr 2010, 22:25
Offline
A Regular Member
User avatar
I noticed your review on the Axminster site Olly :lol:
Thanks everyone for the replies. As this isn't something that is going to be used 24/7 - my SXE 425 will be what I continue to usually use - and as it doesn't need the accuracy of say a plunge saw or domino I really don't think that the festool price can be justified particularly as metabo and perhaps other offer a 3 year warranty.This used to be a selling point for the festool gear. So far I don't have any dewalt tools as I had gathered from numerous reports that their quality in general had gone down in recent years but this may be an option from the positive comments here. Decisions decisions :? :lol:
Steve
_________________
 Profile
 Post subject:
PostPosted: 29 Apr 2010, 22:31
Offline
Settled in Member
User avatar
Has thanked: 18 times
I bought a ryobi a few years ago - similar to this one (£30)
http://www.tooled-up.com/Product.asp?PID=141845
and have no problems with it - I'm a DIY user but it has an excellent mains lead length but like other posts it has a specific paper size. i just put 2 x abranet pads on (as these end up wider than the sander that can be useful)/
I remember at the time looking at the dewalt but this was half the price and has sanded perfectly. the dust collection is very good as well.
Dave
_________________
Dave
Hobby woodworker who's famine in published articles has ended with scrabble in GW 216
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 5 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
 Similar topics   Author   Replies   Views   Last post
Another palm sander ...
in Buying Advice | Tool Reviews
Alexam
3
415
10 Mar 2017, 13:11
Delta / Palm Sander Advice
MotamJoinery
1
332
27 Jan 2017, 10:58
Guide rail compatability: Makita, Bosch/Mafell
LJM
3
499
11 May 2017, 19:11
Metabo SXE400 240v 80mm Disc Sander 220w
in Finishing Advice
timber
2
228
01 Dec 2017, 09:58
Bosch peb 500 e sander - any opinions?
graduate_owner
13 Aug 2017, 20:03
Register UKW
User Tools
UKW Local
Quickly find the nearest tool suppliers & timber merchants in your area
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
UKW Terms & Privacy
