Not registered?? Click HERE to join our community
Veritas Skew Registration Jig for Mk.II Honing Guide Review
Post new topic   Reply to topic    UKworkshop.co.uk Forum Index -> Hand Tools
View previous topic :: View next topic
Author Message
Alf
Hand Tool Goddess
Posted: Mon May 01, 2006 8:47 am Post subject: Veritas Skew Registration Jig for Mk.II Honing Guide Review Reply with quote
So how d'you bring something new to a review when there's already one out there by someone who's already done the thing thoroughly and has had longer exposure to it and its development? Easy; you bring ignorance to bear. Hey, I can do that... Wink So taking the steps that so many buyers are likely to do, I decided to try it without reading the instructions.
The jig itself is quite a large fan of aluminium, tapped with various holes to take shiny knurled brass knobs, grooved to take an aluminium fence and liberally covered with a numbered scale. All beautifully finished and far too good for a honing guide. But I digress.
With rapier insight I deduced this should be fitted in the sliding dovetailed bit at the front of the MkII instead of the registration jig provided with the guide. By a lucky guess I put it in the right way up – what appears to be “upside down”, with the scale readable from below.
The clamping widget thing has a mark on it which I assumed meant the same as with the standard registration jig, so I set it for the width of the blade I was going to hone.
Oh, so that doesn't mean that then? Rolling Eyes
Heigh ho, move it over a bit and get the blade so it's more or less centred in the blade clamp. So far, so good.
I'd already ascertained what angle the test blade bevel was already honed at (feeble excuse to use a new toy – if the low angle block had a skewed blade I'd be getting that in here too... Embarassed )
... so I assumed I should set the fence doodah at the “25” line as indicated down the side.
Still haven't a clue why I need the scale or that sticky-out bit on the fence/stop doodah, but I slid the fence along and tightened it up, then moved the blade to butt against it. All flush and I assumed ready to go? That was easy. The proof will be in the pudding.
I twizzled the micro bevel knob thing to give me a secondary bevel of, presumably, 27° and honed.
Success! I put some marker pen on the bevel so it'd smile nicely for the camera. This is using the cambered roller btw, because I forgot it was on there until after I'd finished... Rolling Eyes Note how straight it is? No extra effort required on my part. Whistle
But what's the scale and stuff for? Well lessee... The fence/stop widget flips over to put the sticky-out bit on the other side if required. So evidentally that's to accommodate skews of both left- and right-hand varieties. Neatly done.
The clamping knob happens to be apparently over-long, the excess being unthreaded, so I presume that's the “pivot” stop that lines up with the scale. Again, a pleasing bit of design. Hmm, line up the sticky-out bit on the fence with one of the lines on the scale, 45° in this case, and we can get the edge of the blade lined up with the line and get a known skew angle, huh? Right, got it.
Presupposes I have a clue what skew angles my blades are at, or that planes in particular are well-machined/built enough to have accurate skew angles across every example of model X... Not always the case, even with new planes. Think I'll stick with my scale-less method.
So how about using the stops to get a set of blades for a #46 skew combination plane all the same? First let's line up a blade I know is correct. Snug it up against the centre pivot point at one end, and butt the edge up tight against the fence (running in the correct groove for the required bevel angle of course), bring the fence along so the stop is butting against the edge of the blade at the bevel end and lock off.
Right, remove the correctly skewed blade and replace with one that's slightly off. Butt the edge against the centre pivot stop and the fence stop and tighten up. Hmm, just a fraction off the correct angle so just as well I didn't just butt the bevel against the fence any old how.
As it happens I want to hollow grind this iron, so I'll get close to the skew using the grinder anyway, but in principle... Wink Laughing
Well now's the time to look at the instructions then. Ack, not exactly easy to read, but I think I've worked out the gist all by myself. Hah. Okay, so my terminology may be a little different... Anxious Just one option I hadn't thought of; determining the skew angle like this:
Heck guys, while you were at it you could have put 20°, 25°, 30° and 35° notches in the top edge so I didn't have to buy the bevel angle measuring wotsit. Rolling Eyes Wink
Anyway, it's nicely made, works very easily and does what it says. Personally I think the scale is a bit unnecessary, but if they hadn't put one I bet there would have been grumblings from all you engineering types who like scales and figures. I'd sooner take the skew angle off the plane, just in case (bitter experience in operation there); as for a chisel, well does the number of degrees really matter? But I'm sure I'm a lonely minority. Anyway, don't be put off by the scale – it's not at all confusing if you just ignore it... Laughing Do you need one? Yeah, like a hole in the head. Instead of being content to sharpen all the skew blades you already have, you'll find yourself dusting off a 5 year old to-do and making a pair of skew chisels just so you can use the damn jig... Rolling Eyes
Or is that just me...? Think
Seriously though, you don't actually need it, any more than you needed the registration jig that came with the MkII in the first place. But like that jig it does make life that little bit easier, which is, after all, rather what a honing guide is all about.
Right, I'm off to read Derek's review now and see how I should have done it... Embarassed
Skew Registration Jig £ currently unknown $24.50
Once again, I wouldn't have this to review if it hadn't been sent to me by those hockey-lovin' Canadian folks at Lee Valley. However, as usual, I've done my best to be as impartial as possible...
_________________
Regularly Musing from the Workbench again: Das Blog
Back to top
View user's profile Send private message Visit poster's website
Waka
Master Cabinetmaker
Posted: Mon May 01, 2006 10:31 am Post subject: Reply with quote
Alf
Yet another excellent review in your inevitable style.
As to whether its needed I can asure you I need all the help I can get on the sharpening front, so another little item for the WS when Brimarc get them in.
Have a great May Day in the WS.
_________________
Waka
The woodkateer who's plane mad.
Back to top
View user's profile Send private message Send e-mail
paulm
Master Furnituremaker
Posted: Mon May 01, 2006 12:06 pm Post subject: Reply with quote
Alf,
Although I haven't any intention whatsoever of purchasing one of these, having no discernable need for one (obviously I'm not trying hard enough Laughing ), I always love reading your reviews just for the fun of it, as well as for being informative as well of course .
Thanks for taking the time to amuse and inform (I guess the entertainment is on purpose, right ?) Shocked Laughing Laughing
Cheers, Paul
Back to top
MikeW
Cabinetmaker
Posted: Mon May 01, 2006 1:17 pm Post subject: Reply with quote
Quote:
...Thanks for taking the time to amuse and inform...
Yes, Alf! Many thanks for both info and a bit of humor to start my day.
One thing about Derek's review--he is an analytical type and his reviews fill the need of many who wish to have it explained, well, analytically. And that's not a knock, Derek. My mind too works thatta way.
Yours adds the balance: A bit of whimsy added to a no-nonsense here's-how-simply-do-it-folks review.
What a way to begin the new day.
Thanks, Mike
Back to top
View user's profile Send private message Send e-mail Visit poster's website
Paul Chapman
Master Cabinetmaker
Posted: Mon May 01, 2006 7:44 pm Post subject: Reply with quote
Yet another great review, Alf Wink
Paul
Back to top
Derek Cohen (Perth, Oz)
Posted: Tue May 02, 2006 6:59 am Post subject: Reply with quote
No offence taken, Mike, since I agree. Alf, you have a great knack of making a review fun. I love reading your stuff. It is hard for me to shake the scientist-researcher side of my life. I think that our approaches are everyone else's gain since they get the info from different perspectives.
Regards from Perth
Derek
Back to top
Alf
Hand Tool Goddess
Posted: Tue May 02, 2006 7:55 am Post subject: Reply with quote
Aww, give over, youse guys. You're making me blush again.
No questions? No mistakes? Shocked Mind you, no "nice chisel handles, Alf" either, so that balances things out... Wink Laughing
Mike, Derek, I quite agree. I think by happy chance our styles of reviewing compliment each other rather well. Bit of luck that Derek gets the hard work side of the thing while I just get to crack jokes... Dancing
Cheers, Alf
_________________
Back to top
Jasper Homminga
Woodworker
Posted: Tue May 02, 2006 9:02 am Post subject: Reply with quote
Nice chisel handles, Alf. Wink
Jasper
Back to top
Alf
Hand Tool Goddess
Posted: Tue May 02, 2006 10:48 am Post subject: Reply with quote
Too late now. Not talking
Cheers, Alf Wink
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    UKworkshop.co.uk Forum Index -> Hand Tools All times are GMT + 1 Hour
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
UK, tools, machinery, woodworking, DIY, wood, drills, saws, power tools, second hand machinery, table saw
Powered by phpBB © 2001, 2005 phpBB Group
UKW Terms & Privacy
Follow UKWorkshop on Twitter
