Not registered?? Click HERE to join our community
Camber Unit for Veritas MkII Honing guide - Animated Review!
Goto page 1, 2  Next
Post new topic   Reply to topic    UKworkshop.co.uk Forum Index -> Hand Tools
View previous topic :: View next topic
Author Message
Alf
Hand Tool Goddess
Posted: Fri Apr 28, 2006 5:08 pm Post subject: Camber Unit for Veritas MkII Honing guide - Animated Review! Reply with quote
Well kinda animated anyway. One bit of it at least... Oh, just read the blasted thing. Rolling Eyes
Question: What's the major drawback to the MkII?
Answer: That wide roller.
What? I hear you protest. But that's what makes my blades nice and square. P'shaw, say I. (Yes I do, really.) But then I'm heavily in favour of using a cambered or crowned iron in the majority of my bench planes. If you are too, this is an addition to the MkII you're going to want to have. If you don't know what in blazes I'm talking about, you don't need it. Yet. Move along, nothing to see here. Smile
The cambered roller comes already mounted in a separate lower assembly, so it's simply a matter of removing the one with the wide roller and mounting the cambered one instead. 10 second job. Nice. Apart from the camber-iness, the rest is identical as you can see below. From left to right, the original straight roller, production cambered roller and the tester one I've been using for the past months.
Except, no, wait, the knob for adding a degree or two of micro bevel is shorter. Hmm, now why...? Think A quick trial on the workbench reveals the old tester roller won't tilt to its full extent to the right 'cos the longer knob hits the benchtop first. Now why didn't I have any trouble with that? Ah ha, because I use narrow stones. For the Scary Sharp-ists and the like, that could be a problem. So the production roller is improved – good catch someone (irritating that it wasn't me... d'oh! Laughing)
A close look at the roller reveals it's a normal “flat” cylinder in the middle section, like the wide roller, before it curves away. This is handy, 'cos it makes honing straight with the cambered roller really a doddle too. Observe proper honing guide use, applying the pressure to the tip of the blade and not the roller, and it's easy peasy. The only problematic blades are the narrow chisels, but as they're problematic with the MkII anyway...
What can I say? It works. Look:
<Homer> Guide goes straight. Guide goes tilt. Guide goes straight. Guide goes tilt.</Homer>
That was the animated bit, btw...
You don't have to fight the wide roller problem when you want to tip your blade to create the camber of your desires, making Camber Creation much more controlled. And that's also why I haven't bothered you with pics of “Cambers I Have Made”; it's still down to the user to provide the control, and that's exactly what I like. This isn't going to make a perfect camber with no effort on your part, so don't delude yourself on that score. I've been using it these past, ooo, six months? and the original roller's been gathering dust pretty much the whole time. To sum up then:
Want to easily create cambers on your plane irons while using the MkII?
Get a MkII camber roller unit doodah.
Sheesh, I could have just said that at the beginning and saved us all some time really, couldn't I? Rolling Eyes
When's it coming out? – No idea
What's it going to cost? – No idea of that either
Next week's lotto numbers? - You're just being silly now...
_________________
Regularly Musing from the Workbench again: Das Blog
Back to top
View user's profile Send private message Visit poster's website
Nick W
Master Furnituremaker
Posted: Fri Apr 28, 2006 5:23 pm Post subject: Reply with quote
Alf,
Nice review, thank you for doing it.
One thing that has been bothering me about this idea is how it copes with low bed angle blades (i.e. BU jobs). To get the same effective radius on these you need to pare the corners further back than you would on a 'normal' plane where the blade is held at a higher angle - if you catch my drift. Anxious
Have you found this to be a problem? Do LV have any plans to bring out rollers with varying radii (and even shorter knobs Very Happy ) to cope?
_________________
Nick Webb
A little learning is a dangerous thing; drink deep, or taste not the Pierian spring: there shallow draughts intoxicate the brain, and drinking largely sobers us again.
Alexander Pope (1688 - 1744) in An Essay on Criticism, 1709
Back to top
View user's profile Send private message Send e-mail Visit poster's website
Paul Chapman
Master Cabinetmaker
Posted: Fri Apr 28, 2006 5:34 pm Post subject: Reply with quote
Nice review, Alf. Up to your usual high standard.
I like the movie bit Wink
Paul
Back to top
Alf
Hand Tool Goddess
Posted: Fri Apr 28, 2006 5:50 pm Post subject: Reply with quote
Nope, seems to be plenty of lattitude for aggressive cambers. To be honest it could just have easily been a narrow roller as curved - it's the absence of roller more than the curve of it that's the key as far as I can see.
Cheers, Alf
_________________
Back to top
MikeW
Cabinetmaker
Posted: Fri Apr 28, 2006 6:00 pm Post subject: Reply with quote
Nice pics, Alf.
Oh, nice write up too Very Happy
Nick, I don't know how Alf does hers, but for the BU planes I have, I first carefully shaped the blades as I wanted them using my stationary belt sander. Which is what I am accustom to if my wife's Tormek is not set up. But I've used both.
Then using the guide with the cambered wheel can maintain it. Otherwise it is a bunch of honing to get it ready by hand. I don't have the patience.
My guess is because LV was hesitant to meet this "need" for a cambering plane blades using the MK.II--remember the original is still in production and works well--they would not be producing rollers with different cambers.
But, with this cambered lower unit, you can go quite tight on the radius. My LN scrub has a 3" radius, my pattern maker's planes and rounds from my hollows and rounds all can be easily honed using it.
The picture below is my scrub plane blade. If you notice, the honing was more even than my grinding as there is a flat spot or two the honing took out.
Take care, Mike
Back to top
Alf
Hand Tool Goddess
Posted: Fri Apr 28, 2006 6:19 pm Post subject: Reply with quote
Serious jack/scrub camber on the grinder first, smoother/jointer camber with the guide from a straight grind. Serious stock removal is never fun with any form of honing.
Cheers, Alf
_________________
Back to top
Shady
Furniture Maker
Posted: Fri Apr 28, 2006 7:40 pm Post subject: Reply with quote
Hmmm... So, looking at that picture - how long have you been using gold plated scrub plane blades Mike? Typical - you decadent wealthy Americans... Wink
Back to top
Alf
Hand Tool Goddess
Posted: Fri Apr 28, 2006 7:57 pm Post subject: Reply with quote
That's just the reflected glow from the golden aura of the Shaptons... Wink Laughing
Cheers, Alf
_________________
Back to top
Waka
Master Cabinetmaker
Posted: Sat Apr 29, 2006 6:17 am Post subject: Reply with quote
Alf
Thanks for the review, excellent as always.
_________________
Waka
The woodkateer who's plane mad.
Back to top
Philly
Master Cabinetmaker
Posted: Sat Apr 29, 2006 9:05 am Post subject: Reply with quote
Great review, Alf-animated clips? Whatever next? "The Frampton Workshop" series on TV?? Wink
So no idea when this little beauty might be available in the shops, then? Why does Rob taunt us so? Laughing
Philly Very Happy
_________________
The PhillyBlog!
Back to top
Derek Cohen (Perth, Oz)
Posted: Sat Apr 29, 2006 9:31 am Post subject: Reply with quote
Hi Alf (and all)
Excellent review as usual.
I don't have the production roller, only the pre-production version that LV sent me for feedback/opinion back in October last year. So I though I would just piggyback here and supply a few additional comments and pictures.
Until your comments, I was not aware that there was a modification to the knob - all my honing is on Japanese waterstones, and the knob rides clear on these.
As I mentioned elsewhere, the straight roller has a definite place to play - not only is it easier for novice sharpeners to maintain a straight edge (a bit like training wheels), but it is near-essential for the straight edges on shoulder planes and chisels.
The cambered roller does require a little more experience/technique if a straight edge is to be maintained (and a camberd one is inadvertantly not to be created).
Firstly, I had no difficulty honing a straight blade with the camber roller. My technique is to maintain even pressure on the central section of the blade (two fingers forming a "V"). Picture is attached. I honed several straight edges with the roller, including three blades (25/33/50 degree bevels) when assessing the BU Jointer, as well as the above. The BD Stanley and LN blades were honed at 25 degrees (with a 1 degree microbevel), and the LAS at 50 degrees.
For markedly cambered blades, such as those for scrub planes, I first grind the desired radius on my belt sander.
Honing the scrub plane blade demonstrated that the camber roller could follow the complete arc of the blade. This had a primary bevel of 30 degrees and a 1 degree microbevel. In the picture below you can see the glint of the microbevel. I believe most who use this roller to hone a scrub blade will find its performance satisfactory.
The method I follow when honing cambers on smoother blades is a slightly simplified version that David Charlesworth used in his sharpening video. While the A2 LV blade required greater effort to hone than the HCS of the Stanley and LN (pre-A2 blade), all were honed with a fine camber. The camber could just be seen with a straight edge against the light, and planing failed to create any train tracks when using these planes.
I suggested to LV that my upside-down Honing Guide method is still easier to rotate than the roller (which, in hindsight, may have represented the limitations of the knob), but overall the roller is simpler to use (e.g. it does not need a card scraper blade to protect the sharpening medium).
The bottom line is that the camber roller works very satisfactorally.
Regards from Perth
Derek
Back to top
Guest
Posted: Sat Apr 29, 2006 9:45 am Post subject: Reply with quote
Nice reviews Alf and Derek
What can I say, I asked for this many times on here, I plane tested for Veritas BUT this is the first time I've seen this and I want one NOW.
Rob, when can I get one????????
Back to top
engineer one
Master Cabinetmaker
Posted: Sat Apr 29, 2006 11:44 am Post subject: Reply with quote
come on tony, surely you actually wanted it yesterday? Laughing Laughing
i still think that the only flaw with the mk11 is that there is no
real sideways location on the actual guide, rather than the jig.
with the two screws, it is difficult for some, (i.e me ) to be
sure that the blade is solidly located in a square way all the time.
the idea is great, it just needs fine tuning.
thanks for looking after the customer Rob,
paul Wink
Back to top
MikeW
Cabinetmaker
Posted: Sun Apr 30, 2006 3:55 pm Post subject: Reply with quote
Remember this thread from July-August of 2005?
This response in particular?
Sorry, couldn't resist Laughing
Take care, Mike
Back to top
Guest
Posted: Sun Apr 30, 2006 9:47 pm Post subject: Reply with quote
Remember this [url=**REPORT TO MODERATOR****REPORT TO MODERATOR**.ukworkshop**REPORT TO MODERATOR**/forums/viewtopic.php?t=5830&postdays=0&postorder=asc&highlight=cambered+roller&start=0]thread[/url] from July-August of 2005?
This response in [url=**REPORT TO MODERATOR****REPORT TO MODERATOR**.ukworkshop**REPORT TO MODERATOR**/forums/viewtopic.php?p=67511&highlight=cambered+roller#67511]particular[/url]?
Take care, Mike
That was not the first time of asking either Wink
Back to top
Display posts from previous:
Post new topic   Reply to topic    UKworkshop.co.uk Forum Index -> Hand Tools All times are GMT + 1 Hour
Goto page 1, 2  Next
Page 1 of 2
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
UK, tools, machinery, woodworking, DIY, wood, drills, saws, power tools, second hand machinery, table saw
Powered by phpBB © 2001, 2005 phpBB Group
UKW Terms & Privacy
Follow UKWorkshop on Twitter
