UKWorkshop Woodworking Forums
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 10 posts ]
Author Message
 Post subject: Veritas beading tool
PostPosted: 15 Mar 2009, 15:01
Offline
Valued Contributor
User avatar
Has thanked: 15 times
Been thanked: 64 times
Martin Brown of BriMarc kindly sent me, on loan, the recently introduced Veritas Beading Tool to have a play with. Here are my impressions.
This is the tool as supplied
It comes with one single-point cutter and 5 blank cutters which the user can shape. As these can be shaped both ends, there are potentially 12 cutters as standard. Additional beading, fluting and reeding cutters are available as extras.
These are the component parts of the tool
As with all Veritas tools, it is very well made and finished. The handles are Bubinga - the knob-shaped one pivots from horizontal to vertical.
The fence is innovative in that it can be secured in three positions - for straight, curved or bullnose work
Then there are two options for each position by flipping the fence over, depending on whether you want to work right or left-handed.
The blade is secured by a clamp and can be slid along the length of the sole
Beading tools (or scratchstocks as they are sometimes known) come in a variety of shapes, sizes and designs and many are shop-made. Here's a very basic one made from plywood
And here's one, made from brass, which Pete (Newt) very kindly made for me
So I think it's fair to say that there isn't a "standard" style of beading tool. When I first saw the Veritas, I thought it looked a bit odd because of the handles but in use I found it very comfortable. I found this the best way to hold it
Two thumbs behind the cutter and one finger pressing against the fence.
The comprehensive instruction sheet gave no information about direction of cut, but a one page leaflet packed with the tool said that it should be used on the pull stroke rather than the push stroke. However, I instinctitively wanted to push it and found that it worked perfectly well that way. The only difficulty I found was with the fence which projects only one side of the body, which results in little contact with the workpiece at the end of the stroke
I did a comparison with my brass scratchstock where the fence projects both sides of the sole
I found this better. However, with a little care, both produced identical results, so it's not a big problem
I had a piece of oak left over from a 3' diameter table-top which I'd cut out, so tried the curved fence on this. Although it was fairly coarse wood and not ideal for beading, the curved fence worked well and the tool cut nicely
Overall, I'd rate this as a very nice tool which works well. The most innovative part of it is the fence which will enable you to use the tool on virtually any type of beading work. However, I just wish it projected both sides of the sole.
Cheers :wink:
Paul
Share on Facebook Share on Twitter Share on Digg
 Profile
 Post subject:
PostPosted: 15 Mar 2009, 15:26
Offline
Prolific Contributor
User avatar
Has thanked: 0 time
Been thanked: 3 times
Paul - good review. I had a play around with mine and found it cut best on the pull stroke (I think :? ) but I still found it a bit awkward to use and set up...I think plenty of practice is needed to get proficient in it's use. For straight stuff a top quality brass scratch stock made by you know who :wink: :wink: is always the tool I'd pick up first - Rob
_________________
The Blokeblog
 Profile
 Post subject:
PostPosted: 15 Mar 2009, 18:11
Offline
Regular Contributor
User avatar
Has thanked: 0 time
Been thanked: 0 time
Comprehensive review Paul and high quality pictures.
_________________
REGARDS PETE
 Profile
 Post subject:
PostPosted: 16 Mar 2009, 12:13
Offline
Settled in Member
Hi Paul
Have you any idea when it's going on sale, and for how much?
Les
_________________
All the tools - none of the skills!
 Profile
 Post subject:
PostPosted: 16 Mar 2009, 12:24
Offline
Valued Contributor
User avatar
Hi Les,
It's listed on the Axminster website for £56-95 http://www.axminster.co.uk/product.asp? ... GN06N0VIMJ
Cheers :wink:
Paul
 Profile
 Post subject:
PostPosted: 16 Mar 2009, 12:47
Offline
Settled in Member
Thanks Paul - I never thought to check their site - duh! - (homer)
They must have sneaked it in while I wasn't looking....
The Bad News is they're out of stock - snapped up by UKW members prhaps? :evil:
Les
_________________
 Profile
 Post subject:
PostPosted: 16 Mar 2009, 12:50
Offline
Valued Contributor
User avatar
Yes, just spotted that. A 'phone call to BriMarc might be the best way to find out when they are going to be available.
Cheers :wink:
Paul
 Profile
 Post subject:
PostPosted: 16 Mar 2009, 15:14
Offline
Valued Contributor
Has thanked: 2 times
Thanks for that Paul.
I have just read Rob's brief review in F&C and was thinking about these as I would like to progress to adding these kind of subtle details to future projects, so I might give it a look.
Also have grand ideas of making a scratch stock of my own, but have never done any of my own metalwork so that might start me off on a whole new slope....
Mark
 Profile
 Post subject:
PostPosted: 17 Mar 2009, 22:36
Offline
Valued Contributor
User avatar
Has thanked: 161 times
Been thanked: 67 times
Excellent review Paul - I bought a piece of brass (£30 worth!) to make a Newt style one - ONE DAY???
Hope you do not mind Pete?
Rod
 Profile
 Post subject:
PostPosted: 12 Oct 2010, 15:16
Offline
Participant
Has thanked: 0 time
Hi to everybody; here you could see the translation in italian of the review; thank you very much
_________________
Antonino
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 16 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
 Similar topics   Author   Replies   Views   Last post
beading tool and parting tool.
in Wood Turning - Lathes
marcros
14
465
21 Dec 2017, 23:09
Veritas String Inlay Tool System - Review
in Buying Advice | Tool Reviews
cowfoot
1
645
18 Feb 2017, 18:41
setting up the beading plane
in Hand Tools
thetyreman
14
618
14 Sep 2017, 16:55
Fixing beading to cabinet doors
in General Woodworking
Doug71
20 Nov 2017, 13:32
Priming beading for emulsion paint finish?
in Finishing Advice
Doug71
1
309
23 Aug 2017, 20:10
Register UKW
User Tools
UKW Local
Quickly find the nearest tool suppliers & timber merchants in your area
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
UKW Terms & Privacy
