| View previous topic :: View next topic |
| Author |
Message |
WoodAddict Furniture Maker
Joined: 04 Feb 2010 Posts: 402 Location: Rothley, Nr Loughborough
| Posted: Mon Mar 08, 2010 12:30 am Post subject: Variable speed control. |
Hi Guys,
Just wondering how often you use your variable speed function on your Scroll Saws? It seems to be up to £50 difference in a new saw with and without the variable speed feature.
I'll be cutting portraits, puzzles, and making parts for toys. My thoughts were that the tilt in the bed would come in handy but I wasn't sure that the variable speed was worth the extra cash?
Whats your thoughts?
Paul |
| Back to top |
Mouse Woodworker
Joined: 07 Jan 2010 Posts: 103 Location: Driffield, East Yorkshire
| Posted: Mon Mar 08, 2010 8:38 am Post subject: Re: Variable speed control. |
| WoodAddict wrote: | Hi Guys,
Just wondering how often you use your variable speed function on your Scroll Saws? Paul |
Hi Paul,
I use mine a lot, different blades, material, and complexity of cuts IMHO require diferent speeds. _________________ Rules are for the guidance of wise men and the blind obedience of fools: Douglas Bader
Mick |
| Back to top |
Carter Johnson Woodworker
Joined: 03 Sep 2005 Posts: 114 Location: near Chicago, US
| Posted: Mon Mar 08, 2010 3:17 pm Post subject: |
When starting delicate cuts with a brand new blade, it's useful to slow the speed down for the first few cuts so you dull the blade and make it more controllable. Can't do that with a single speed saw.
Also, some of the blades I use for my puzzles are so delicate that they shake to pieces at very high tensions and speed. Makes sense to slow things down.
So YES, it's worth it. and more phun..... Carter |
| Back to top |
StevieB Master Furnituremaker
| Posted: Mon Mar 08, 2010 3:24 pm Post subject: |
Yup, well worth it. Some of us cut slow and steady, others like a faster rate of cut. Personally I use quite a slow feed rate and cut and the variable control is nice to get it where you feel comfortable. That said, once I have it where I want it I tend not too vary much.
Steve |
| Back to top |
| Posted: Mon Mar 08, 2010 8:27 pm Post subject: |
Thanks chaps.
I suppose it's a no-brainer then! Variable speed it is!  |
| Back to top |
Eda Forum Newbie
| Posted: Tue Mar 09, 2010 7:40 pm Post subject: |
Definitely.
I could not cut puzzles without variable speed. |
| Back to top |
Schummie Forum Newbie
| Posted: Sun Mar 21, 2010 5:00 pm Post subject: |
Does anyone know or there are separate speed controls for a
Scroll saw?
In the US they sell a lot off different speed controls, but only 110v and we have
here 220v.
I have a Hegner scroll saw without speed control.
Thanks Schummie. _________________ Greetings from the Netherlands |
| Back to top |
Mouse Woodworker
| Posted: Sun Mar 21, 2010 6:50 pm Post subject: |
Hi Schummie,
As far as I know, but I may be wrong, the motors are a different type on models with speed control. I can find nothing here in the UK _________________ Rules are for the guidance of wise men and the blind obedience of fools: Douglas Bader
Mick |
| Back to top |
goose Woodworker
| Posted: Sat Mar 27, 2010 5:25 pm Post subject: More than you think |
I have an old single speed hegner.
You need the strobe controller, to get variable speed. A kit from Hegner, but given the price, your probably better to ebay your old single speed and put the cash toward a variable on ebay. But it can take some serious hunting to find one.
BUT before you flog your single speed. Yes variable speed is handy, but single speed can be used for lots of things. Also check, your single speed, may infact have two pully options, so you can change the ratio. Check, not all can.
I cut small pieces without too much trouble. Yes it takes a lot of concentration and you have to be gentle and very careful when re-starting a cut on asingle machine to avoid getting "chunk" chewed out as the blade bites, but I think if your starting out, a single speed is perfectly capable to doing a lot of different styles of cutting and work. |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
UK, tools, machinery, woodworking, DIY, wood, drills, saws, power tools, second hand machinery, table saw
