UKWorkshop Woodworking Forums
Post new topic Reply to topic  [ 12 posts ]
Author Message
PostPosted: 30 Jul 2016, 17:40
Offline
Participant
Has thanked: 15 times
Been thanked: 0 time
I'm new to this woodworking lark :)
I got some rough wood that I was curious to know the moisture content of. So I grabbed a highly reviewed "Wood Moisture Meter" from Amazon and stabbed the wood with it. I was getting readings between 1 and 4 percent.
I was surprised how low this is. Is this normal? Is my meter working ok?
I want `stable` wood so I'm hoping this is legit.
Share on Facebook Share on Twitter Share on Digg
 Profile
PostPosted: 30 Jul 2016, 17:44
Offline
Regular Contributor
User avatar
Has thanked: 172 times
Been thanked: 110 times
That does sound low, I think around 12-14 is considered "normal" for an acclimatised bit of wood, although it will vary with humidity, seasons, central heating etc
 Profile
PostPosted: 30 Jul 2016, 18:53
Offline
A Regular Member
Has thanked: 105 times
Been thanked: 113 times
There is something seriously wrong there.
As Woodmonkey said, you would normally be looking at the 10 - 14 mark depending on how the wood was stored. You can normally air dry timber to about 14% and then most people will bring it indoors to acclimatise to where it will eventually be housed. So a modern CH house would be around 11% and an old damp drafts Victorian one maybe 13 / 14%.
I've never come across timber that dry (even when I tried to microwave a turning blank) so it is either down to your moisture meter or how you are using it. If it's genuinely that dry (which I doubt it is), don't make anything out of it as it will distort / crack / spilt.
 Profile
PostPosted: 30 Jul 2016, 19:16
Offline
Settled in Member
Has thanked: 0 time
Been thanked: 13 times
Sounds like an inaccurate reading from the meter. If it has probes try drilling a small hole (or 2 if it has 2 probes) and
try then as it may just reading from the surface.
 Profile
PostPosted: 30 Jul 2016, 19:27
Offline
Participant
Good info, thanks all, might plane a bit off or indeed make some holes and probe the wood deeper in.
thanks!
 Profile
PostPosted: 30 Jul 2016, 19:34
Offline
Settled in Member
Has thanked: 2 times
Been thanked: 26 times
I've yet to find timber with a moisture content below 14%.I don't own a moisture meter and have no plans to acquire one as I don't believe they are based on principles that relate to real world results.Measuring resistance between probes on the surface of the wood may tell you a bit about the moisture content at the surface,but can you rely on it to take account of any variation of moisture content with distance from the surface?If I want to know the moisture content of a sample I use a well controlled oven and a set of accurate digital scales.Weigh the sample and then give it an hour and a half in an oven at around 105 deg C and then reweigh.A few moments of calculating tells me the real moisture content.
 Profile
PostPosted: 30 Jul 2016, 19:40
Offline
Moderator
User avatar
Has thanked: 94 times
Been thanked: 646 times
Place the moisture meter prongs across the face of your finger (not stuck in it, it hurts) read 20% or thereabouts?
_________________
Chas, just a traveller on the road of time.
Bits & Pieces Gallery----Web Site----Forum Links
 Profile
PostPosted: 30 Jul 2016, 20:30
Offline
Settled in Member
Has thanked: 0 time
Doesn't that depend on how mush you have had to drink Chas ? :)
 Profile
PostPosted: 31 Jul 2016, 13:09
Offline
Participant
Has thanked: 0 time
Been thanked: 3 times
The better, more accurate moisture meters seem to be the ones using microwaves rather than pin contact to achieve a reading. But they're not cheap. As has already been said....it looks like your Amazon kit could be faulty.
 Profile
PostPosted: 31 Jul 2016, 14:54
Offline
Valued Contributor
Has thanked: 17 times
Been thanked: 76 times
I have posted about my efforts with an inexpensive meter here:-
a-basic-moisture-meter-t99178.html.
Woodgears site, https://woodgears.ca/lumber/moisture_meter.html has some interesting reading.
The relavent bit being tests done at a depth of 8mm.
xy
_________________
gk_Postscript_Plot, A plugin to allow full scale printing from Sketchup, is available for both PC's and Mac's, same Ruby plugin, from here:-
https://app.box.com/s/zqreq818orwm8lgcson9
 Profile
PostPosted: 31 Jul 2016, 19:05
Offline
A Regular Member
Has thanked: 3 times
Been thanked: 29 times
I have a cheap moisture meter from Lidl
If I touch it to the surface it will give the readings you suggest.
What I normally do is cut the end off the board and test the centre, that way I get a better idea of the moisture content.
It won't be spot on but has helped prove that we have had some wet timber supplied, when the moisture content was 17% in the middle.
 Profile
PostPosted: 31 Jul 2016, 19:49
Offline
Settled in Member
Has thanked: 0 time
Been thanked: 23 times
Once working for a client who had just taken delivery of some logs.
He was boasting that with his meter they were 18%, i said now chop a log in half
and take another reading, 50% in the centre !
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Hemsby, Jorge Rodrigues and 3 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
 Similar topics   Author   Replies   Views   Last post
What wood is this
in Wood Turning - Lathes
tommo 62
7
441
13 Dec 2017, 20:13
Wood rat - what is this
in General Woodworking
hailstones
4
607
13 Nov 2017, 05:06
Another wood ID.
John Brown
13
377
01 Dec 2017, 09:56
Name this wood please?
lastminute
6
435
04 Nov 2017, 14:20
Wood ID please.
Froggy
10
537
08 Feb 2017, 12:33
Register UKW
User Tools
UKW Local
Quickly find the nearest tool suppliers & timber merchants in your area
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
UKW Terms & Privacy
