Clamps doe edge gluing?
LFS19
21 Oct 2015
East Yorkshire
I was wondering what people use here to edge glue boards together?
The ones I see people most often using are sash clamps, but I can't afford those.
Any suggestions?
Thanks allot
You could make up your own with some clamp heads from the likes of Paramo or Record. All I have used for 20 years.
Although they're not as good as the more expensive ones, there are some 4ft clamps available online for about £15 a clamp if that's better for your pocket.
Use hide glue and you don't need cramps at all, just a rub joint until it grabs then prop the assembled top against some sticks lying at an angle against a wall and leave them for a couple of hours.
If it was good enough for Chippendale...
I used bits of wood and folding wedges when i first started but have slowly collected a range of sash cramps. There's just something about using an old Record sash cramp. Reminds me of my school days and my first forays into the wonderful world of wood with Mr Polger, the woodwork teacher. They are called Tech tutors or summat now.
Clamp heads? Would that mean dismantling the clamps and adding extra to then to fit the job?
I see. thanks for the heads up, I'll have a look,
Hide glue - haven't heard of that, I'll check it out. Sounds strong
Yep - design and technology,
If you do woodwork in school now, it has to be incorporated into a metal work, textiles and cooking package :roll:
paulm":2j6r43ei said:
Could use some folding wedges and bench stops or similar.
Cheers, Paul
+1.
This shows some folding wedges I used on a back panel glue up.
You just screw some blocks on any old scrap wood, to make a clamp or two to suit the work in hand. Cost = £0.00
I like to use these panel clamp heads - £16 for the hardware and then you use your own timber to make a clamp as long as you need it http://www.axminster.co.uk/york-panel-clamp-500008
I have the timber pre-drilled at regular intervals in various lengths - you can almost clamp any length
AndyT":2gh3uif0 said:
Cheers, Paul
+1.
Very nice, thanks for the picture
They seem simple enough, thanks for the tips,
I've just come across a Paul sellers video where he uses timber dogs; those also seem a cool and simple option.
Sure - but be warned they leave pretty hefty holes in the end grain...
You could also use a Spanish Windlass approach, or even rachet straps, if you took care to keep the workpieces flat while tightening them up.
Cheers, Paul
