Kity Bestcombi 2000 question
Kity user
New member
20 Dec 2015
Essex
Hi All,
Advice needed. Just purchased a secondhand Kity Bestcombi 2000 and was wondering whether there was an easy way to correct the angle of the table saw blade. When in the 90 degree position the blade is not quite at a full right angle to the deck hence cuts with a very slight angle. I believe it is out by around a degree or so (I.e at 89 degrees when fully back in vertical position) so was wondering if there is an easy way to correct this minor error?
Thanks in advance.
David
There is an adjustment some where I did mine years ago but I can't remember where it is! I seem to remember it was easy to do.
Take the big yellow dust collector thing off the side and have a look, mine was not tilting parallel to the top which can be adjusted but slackening the screws round the rise and fall plate and moving it.
