- Joined
- 11 Mar 2009
- Messages
- 1,315
- Reaction score
- 11
I have had to purchase a new boiler which is being fitted shortly and I have a question regarding the electrical side of the installation. The existing boiler did not have a pump overrun and basically had a switched live / neutral and earth. These fed the boiler from a 3 amp switched spur. Now the new boiler requires a permanent live as well for the pump overrun. The spark who wired the house has put in a permanent live cable fed from the Honeywell unit so that is ok. The question I have though regards isolating these 2 connections. Do I require 2 isolation methods for the 2 lives. eg 2 separate switches. One for the permanent live and one for the switched live?
The switched live, obviously, becomes live when the CH or HW timer clicks on.
Sorry if I have not explained myself very well.
