Monkey Mark
I have an Aldi router, not great but not bad for the price (£25 I think). Anyway, after a cutter slipped during use, which scared the rubbish out of me as it bounced off the floor and flew past my knew, I think the collet and nut needs replacing. Problem is, where to get one?
I've tried searching for the Aldi ones but cant seem to locate one anywhere. However, what I'd really like, is to swap it. The original one does not have the retaining ring thing (not sure what it's called ) on the nut to pull the collet out as you undo it so It would often get jammed in. Probably why it ended up slipping.
Does anyone happen to know which other would fit my router or know of a way to find out?
Cheers, Mark
Cheers, Mark
