DiscoStu
Not sure if this should go in general or turning so apologies if I get it wrong.
I bought a the a little while ago and I found that two things were annoying me.
Firstly that I didn't have anywhere to put the gouges etc.
Secondly that I had to keep walking to the other end of my workshop to my grinder to sharpen.
So tonight I spent an hour and solved both problems with one solution - although you might think I'm mad!
In simple terms I bolted a bit of MDF (made it oversized deliberately) onto the end of the lathe and mounted the grinder on that. I also cut holes in it so that my chisels etc had a home.
Obviously it shortens the length of my bed but I've not used it so far so shouldn't be an issue and if it is I'll just unbolt it.
I'll try and post a photo or two then it's daylight.
Hope you don't think I'm too mad!
