Octogonal gazebo
Den_Kompaniets
15 Aug 2015
Uzhgorod, Ukraine
Hi there, I want to show you a project I recently finished - an octogonal (8 sided) gazebo, and it's construction. More pictures and details soon. (mixed up the name in the title)
Here goes the design:
The posts are 150mm round section, the beams are 120x120mm, rafters, braces, railing - 50x150mm, the railing infill is 50x75.
To add some rigidity I joined the beams with a rigid joint:
Here goes the construction:
First I made the beams, so when they are ready and assembled - I can mark the locations of the posts and avoid mistakes.
The edges of most pieces were routed to look better. Everything is stained dark (it is also an antiseptic)
Then I cut the posts to length and planed them (they were really dusty and rough)
The bottoms of the posts stand on a rubber disk and on pieces of D12 rebar (drilled into the stone base)
The top of the post is connected to the beam assembly by a custom made barrel-nut
Here are the posts and beams assembled. It starts to take shape. (I'm trying on a rafter, with the help of my dad)
Next I made the rafters (by the way every piece is hand-cut by a handsaw) and the top piece that holds them together.
The top of the rafters is connected to the top piece by a dowel, and later screwed there tight. The birdsmouth was tricky - corners.
(on the background - my dad's hobby, an old UAZ that he is repairing)
the top piece (I call it "pencil")
and the assembled joint:
the principal rafter are in place
it's time to make the braces
and screw them in place
Railing is cut into the posts
By the way here is my workbench :)
I decided to make a half-lapped pattern for the railing infill:
made a bevel at the joints to make them more visible
back to the rafters - cut the blocks between the principal rafters and screwed the secondary rafters in place.
The frame is really rigid by now.
Just a few nice views of the frame (rafter-tail attachments not done yet)
Rafter tails are ready:
the roof will be covered with bitumen shingles - 25mm boards go underneath.
The bottom side of the boards is stained
The roof overhang
Covered the boards with bitumen tarp, fixed the edges with sheet metal edging, and layed the shingles
A sheet metal 8-sided pyramid finishes the roof
This is actually my first woodworking project (hmm.. actually I fixed a stool before once).
I recieved a lot of help and advice from my dad, and he bought all the materials - I would like to thank him for that.
I will be happy to hear your questions or comments, thank's for your attention.
Your first project?! Don't let my wife see it.....
Very nicely done
That's mind blowing for a first project !!!!!! Look forward to seeing your next :cool:
Thanks for the answers. Yeah, it's my first project with wood done by me, but I have an engineering background so I used to design all kinds of structures for living, and I saw how others did stuff with wood.. and I have youtube :) Thing is, that I recently got interested in woodworking and timberframing particularly. I started to research the internet and than came the moment when I thought that I have to try to actually build something. coincidentally there was a vacant place for a gazebo in my fathers garden - that's what came out. I am considering now to start a career in carpentry, hope 25 isn't too late to learn :) Got sick of the office routine..
Very impressive! If that's a first time woodworking job, that's amazing.
Thanks for an excellent WIP, Tell you're parent he has a clever son!
Regards Rodders
Excellent work Den. I like the design very much, and just right for gin and tonics when the sun is over the yardarm.
