Boiler cabinet
mailee
26 Jun 2005
grimsby Humberside
Got stuck in on this job today. It is a boiler cabinet for the customer with the corner unit. This will be painted to match the other cabinets in the kitchen and the door will replicate this too. This is now ready for the finish. :D
In this case I just drew lines on it and then set up a temporary jig on the bench. I pinned down the piece and set up two stops top and bottom. Then I used a square offcut of MDF which I clamped in place to rout each flute. I then just moved the square piece and clamped it for each one. I thought about making a dedicated jig but it would have taken longer to make than use this method. HTH. :wink:
