rexon bandsaw blades
Sounds like youre after blades for a smallish saw
and it sounds like theirs no blade length stated on your machines nameplate.
if your blade has not snapped try the following ..
When you tension your blade fully does the upper wheel come very close to the frame of the saw ?
i.e.. the top of the upper wheel nearly bottoms out and rubs against the frame ..
how far is the distance between the bottom of the upper wheel and the lower part of the frame have you got now ?
you'll have to measure your blade with a tape and if it bottoms out on upper frame/cabinet subtract an inch ..
So... if you'd have to make the bottom of the upper wheel rub against the lower part of the frame to install a blade
the blade might be a tad short
It could be that you have to deal with this if you experience both scenarios
If its a small saw the frame could be a bit compressed so stated blade length might not be totally accurate
blades are rarely spot on in terms of length because you can't just cut n weld a half cut tooth to a gullet
so blade choice could be a factor if theirs no room for error
Oh i forgot to mention Just go to tuffsaws for your blades .
Good luck
Tomas
