Home made dust extraction?
Monkey Mark
24 Feb 2015
Durham
This is two questions really. Come about after watching some youtube videos.
Firstly. Have any of you made your own cyclonic dust separator? If so, how well has it worked and where did you find the best information on this.
Secondly, the suction. I have an impelar fan that was removed from an industrial blown air heating system. Although a little noisy I think it would still be quieter than the likes of a vacuum cleaner. Again, has anyone utilised something similar with success?
Impeller will be running at 3-4000 RPMs, so make sure it is well balanced and tested at these speeds.
It's from an industrial unit. It runs nice and smooth.
Graham Orm":211wo06j said:
https://www.youtube.com/watch?v=UopsGH-Yzf4
Graham how far does the outlet (pipe in the lid) protrude down?
I have a bin like yours and wish to make a seperator, I was thinking of 4" so I could connect it to my bandsaw and planer/thicknesser using a soon to be purchased (hopefully) Camvac.
Baldhead
Baldhead
A couple of inches I think. I've moved on from that design now, but I don't think the length of that pipe is critical. The important thing is that the pipe that comes in the side sends the waste around the outside of the bin so it falls down.
That bin was much too thin by the way and would collapse if there was any blockage at all.
Graham
Some time ago, I bought two books, by Time life magazine,- Workshop essentials.
Really excellent read, just the thing I guess Mathius Wandell could write!
The copy with a cross cut sled, on front has all the details you need to build a cyclone separator, also a fine filter and many, many, other useful workshop items, including the sled!
As I am unable to do a link or pic, There's one on e bay for £5.98, inc the post.
Regards Rodders
Regards Rodders
Thanks Rodders.
To insert a link simply copy the address from the address bar and paste it into your comments.
Graham
Regards Rodders
Thanks Rodders.
Graham
Thank's Graham, I'll have a go at that!
Regards Rodders
Ps, Amazon, £2.85. including the post, http://www.amazon.co.uk/Workshop-Essent ... 0783559607
Regards Rodders
Thanks Rodders.
Graham
Regards Rodders
Thanks Rodders, purchased.
Regards Rodders
Thanks Rodders.
Graham
Regards Rodders
Just ordered one too thanks.
Just to add m £0.02 worth;
I'm another home build of cyclone, mine uses a Thein baffle inside a metal drum. Cost next to nothing, easy to build and works a treat. I'm sure I put some pics up before, will try to find them.
My point though is that it's worth doing given the little expenditure in time and money.
I intend making a cyclone or perhaps just a chip separator. What I do at the moment when sanding on the lathe is, I open a window in front of which is a large industrial type fan, about 12" diameter. The opposite side of the lathe is a 9" extractor fan which blows the fine dust towards the 12" fan. It seems to work, although it is slightly noisy !!
I'm intending to make a ducting from the 12" fan to a cyclone / bin and then use 4" pipes to connect up kit via blast gates. I don't know if that is going to work but it's worth a try. I would like 2 pipes to go to the lathe, and then I will do away with the 9" extractor.I also intend to fit a plywood panel into the window, with a 12" circular cutout, and fit the fan to that.
K
How powerful would the impellar
need to be to be effective?
The one I have is smaller than I remembered :shock:
Plate says 1.1A and 875rpm.
Most I've seen are about 1.5KW and 30 - 40cm in diameter.
At 50 Hz, these motors spin at about 2800 RPMs.
This is the one in question.
It's a reasonable size. Presume it has a lower rpm to minimize noise.
Still seems to move a reasonable amount of air.
What did it originally come from ?
Looks like a commercial kitchen extractor to me and given the rating you gave in your earlier post.
It was from an industrial, albeit small industrial, blown air heating system. I may have another identicle one somewhere.
I'm not sure it has enough power to work as a shop vac, but you could use it to shift dusty air out of the shop.
