S&J Hand Planes
I have one already
just going through my collection..need to thin them out
guess this one is out the door
Steve
mine looks a lot older than them
no shiny chrome...so thought it was a bit older
unless all the chrome has rusted away
Steve
Whats the frog like ?
Just found this
http://www.planemakers-database.com/page/4/
CHAPMAN, James Arscott Ltd.
James Arscott CHAPMAN Ltd. SHEFFIELD (U.K.)
Industry Works, 115 Woodside Lane 1868 – 1936
Metal plane maker and joiner’s brace maker. The company is best known for its range of steel braces but also began making Stanley-type planes under the trade name “Acorn” from about 1934 onwards. Like the Stanley planes, the Acorns were painted black on the inside of the casting.
J.A. Chapman also made planes for other makers, most notably GTL, Talco and Spear & Jackson. Interestingly none of these planes have a frog adjusting screw.
In 1936 the company was purchased by The Stanley Works, New Britain, Conn, U.S.A., who then created The Stanley Works (Great Britain) Ltd.
thought i would add some pics :)
That's a lot better than I was expecting so it might be worth a fettle.
My #4 is a black painted pre-Stanley Acorn. It works ok for me, and I will keep it because it was Grandad's. It does lack the frog adjusting screw, and the lateral lever is the cheaper pressed type. But far nicer than a late Stanley or Irwin era Record. So don't dismiss it out of hand.
Early Acorn planes seem to be well made, while the later - Stanley era - were second rate budget planes.
The early Acorn (left) has the frog mating surface angled very much like a Bedrock. It has the potential to be a good plane IMHO. The later Stanley-Acorn has a single horizontal (painted :roll: ) mating surface for the frog like an early Stanley (ref. Blood & Gore type 2) - which has the frog cantilevered out over the mouth (i.e. no support for the frog at the mouth).
So if your S&J was made by Chapman in the early days (and it looks like it might have been) it could have potential.
Cheers, Vann.
I have the one on the left
I am glad I not the only one with too many No4s
I can only use 1
but sometimes it is hard to decide to let them go..but a dozen is a bit too ott
Steve
