Spindle moulder cutter
I don't think that knife will fit a euro block, if that is the cutter you need either get the block to suit or phone Whitehills and ask them to make a pair to fit your euro block, I'm sure that they are doing that kind of thing every day.
The make the same cutter for the Euro block. Try a 411. Depending on spindle rotation (if you have a tenoner) they also do the opposite rotation.
It does seem to be standard cutter for 12mm rebate/ovolo mould. I'll have a rummage through drawer tomorrow as im sure I use it - have it for scribing frames then chisel out the flat bit
