Kity 2000
ian 2000
New member
6 Apr 2014
Lockerbie
Hi I recently purchased a used kity 2000 combination machine , I cant get the feed for the planer / thickness er to work , any suggestions , I did not get a user manual with it.
You need to to fit the dust extraction chute, turning the black knob to operate the switch under the infeed table.
I have one good machines.
If its just the feed than there is a flat lever under the table on the thicknesser infeed side up against the main body of the machine, push it forwards and then down to lock. It operates an idler pully which tightens the belt to the drive when pushed in.
J
