Block plane saw jointer.
swagman
13 Feb 2008
Victoria, Australia
Hi. Does anyone else use a block plane to joint their backsaws.
For larger non spined hand saws I would personally recommend using a jointer plane.
Stewie; :lol:
bugbear":c362h5fk said:
Gloriously and hilariously over the top! Nicely done.
BugBear
Agreed!
This is my simpler solution to the same problem:
It's a bit of framing from an old "Utility" chest of drawers that my parents had. It came with the 1/4" grooves already in place - all I had to do was wedge the file into one of them.
[On the other hand, I'm not always so quick... I do still need to make some file handles so I can sharpen some saws so I can do some proper woodwork ... and I'll get round to it really soon. :wink: ]
BugBear
Thanks Bugbear. Before getting into backsaw making I enjoyed making traditional 1 piece hand planes of all sizes. I been thinking about getting into it again but its been a few years. I had a few hours spare so I thought this would be a novel approach to hone some old skills. The fitting of the file securely within the body of this holder required it be made in a 2 piece construction, so its not quite the real deal I am used too. but I enjoyed the time spent making it. As a jointing tool for saws it works extremely well. I have a box of spare news files when this one needs changing out. Although it should last a very long time before it needs replacing. The file itself it a fine toothed machinist file. As such it quite easy to joint across the tooth line. A handy tool to have at my disposal.
Stewie;
AndyT":2ow4k3jk said:
BugBear
Agreed!
A simple but effective solution for holding your jointer file Andy. I know what you mean when you mention the jobs to do list. Its a common problem that most of us battle with. Maybe next week. See how it goes for time then.
Stewie;
Hi Stewie,
Your works have always something of particulary beautiful!
I'm sure whit excellent results.
Ciao
Giuliano :)
