New lathe.
Hunter 001
26 Feb 2017
Wiltshire
Hi everybody
After reading few posts in here I have just put an order for an Axminster Hobby Series AWVSL1000 Woodturning Lathe.
this will be my first lathe.
now need to look for a set of basic tools, little search showed positive reviews for Robert Sorby 67HS Chisel Set but I wonder if there is any other cheaper alternative.
also is there any other chuck instead of the expensive Axminster K100/K800 and finally any good source to order few sanding papers and some wood finishing oil.
Hello and welcome,
Chucks - Axminster, Record Power and Sorby. Record power is probably the cheapest. Just make sure you get the correct thread to match your lathe.
Chisel (Gouge) sets - Record power again or the Sorbys. Sets invariably contain a gouge or two that you won't use very often if at all so buying individual gouges can be the way to go and may save a few quid (but not a lot) but for simplicity I'd plump for a set.
Sanding Paper (abrasives) Avoid the pound shop stuff, try the RhynoGrip Plusline sample pack from Richard Findlay - https://turnersworkshop.co.uk/woodturnersupplies.html, or Abranet.
You'll also need to sharpen your gouges very often. Cheapest method is a 6" bench grinder with a white wheel and a homemade rest. Again Record Power (can you see a pattern emerging here :) ) for the grinder and the obligatory book, Woodturning: A Foundation Course by Keith Rowley has a guide for making a tool rest as well as being about the best book available for new turners.
nev":pxplirz5 said:
Hello and welcome,
+1 for Nev's advice
I have the Robert Sorby turning set and use all of the tools so not a waste of money in my eyes but the I did not pay for mine as I won them in the very first turning competition I entered
I have a cheap bench grinder with this specification:
- 6" (150mm) grinding wheels
- Power: 150W
- Voltage/frequency: 230-240V/50Hz
- Speed: 2950rpm
- Size of abrasive wheel: ø150mm x 16mm x 12.7mm
- Wheels material and type:
I am trying to buy white alumonium oxide grinding wheel for tool sharpening, what grit shall I buy? 80, 100 or more.
There are some cheap on ebay for just £5. Are they any good?
80 grit seems to be the norm for white ali oxide wheels suitable for HSS gouges.
The RP one is 40mm wide so gives a nice big surface for the sharpening of wider tools etc.
https://www.stilesandbates.co.uk/produc ... 9/sn/RSBG6
If you splash out 20 quid then you may consider a Ruby one too, half way down this page...
https://www.toolpost.co.uk/pages/Grindi ... heels.html
No idea if they will fit your machine, and no experience of cheap eBay wheels but I suspect they are not of the same quality as the more expensive ones.
Some info here...
http://www.peterchild.co.uk/grind/grindingwheel.htm
Why not take a trip up the A34 to Didcot and visit the ToolPost? Peter will give you honest and free advice and even let you try things in the training room.
Dave
There are some cheap on ebay for just £5. Are they any good?[/quote]
Don’t go for the e bay cheapies. I bought an alli oxide 120 grit from Axminster. It comes with several inserts, for different sized grinders. I think it cost about £15 inclusive. I ended up, buying a Robert Sorby pro edge belt grinder. Quite expensive, but worth every penny.
Hi Saw the comment about buying a ProEdge.
Im thinking of getting one worthwhile? Also wonder if there is a similar machine made by others, regards okeydokey
The good points of the Proedge are build quality & repeatable accuracy of the settings. Bad point is the price.
Nothing else like it as far as I know, but elsewhere on the forum it has been suggested that Axminster may have a competitor in the pipeline.
