smaller than 50mm internal dovetail jaws
Chico
16 Jun 2007
Bardney, Lincs..
I have Nova G3 and a Supernova 2 chucks, and looking for a set of jaws with a smaller than 50mm internal dovetail to fit them. It seems a lot of things I need to turn are slightly too small to safely clamp into the standard 2"/50mm, I know I can go internal recess but wondered if I'm missing something out there as I cannot find smaller.
Ta for that but those are obviously for internal dovetail recess or spigot work.
I have now found the Sorby RSJ15 jawset which will solve my problem (and fit my chucks) but a bit steep!
This is Teknatools web page for that jaw set. It shows the jaws clamped on a tenon. the description includes this... All NOVA Chuck accessory jaws are designed to hold in the expansion and contraction modes. Looks like these should do what you want.
https://www.teknatool.com/product/nova- ... y-jaw-set/
James
I've sorted the sorby now, what I got from that site was this
• A great range of smaller projects can be mounted and turned using either the expansion mode (mostly for bowls) or the contraction mode (mostly for spigots)
I need an internal dovetail for holding stuff on the outside of the job i.e contraction.
alexf":2e2074lo said:
I use these http://www.axminster.co.uk/100mm-o-donn ... ets-718321. a bit pricy but very versatile.
Do these fit Nova chucks? I thought either the fitting or screw spacing was different but I stand to be corrected.
Chico - I can't see any smaller internal dovetail jaws on the Teknatool site
- https://www.teknatool.com/product-categ ... cessories/
There is a list of jaw capacities which you can view or download for future reference as a PDF
- https://www.teknatool.com/wp-content/up ... ble-mm.pdf
Robbo, thank you for that, I'll keep it and use it in future.
Sorbys will be here today so problem will be solved.
