Wood stain
GrahamIreland
4 Jun 2015
Nottingham
Hi, has anyone got good results with a coloured wood stain.
I'm thinking of doing a vibrant red, on ash possibly.
Does it work, any product you could recommend?
Graham
Depending on how coloured you want the wood and how much grain/figure you want visible you can get good results simply using paint. Thin it and apply a couple of coats directly to the wood, no primer. Then varnish over the top if needed.
This was a popular technique in the 1980's, including a vividly coloured accent piece in a piece of furniture, often red on a Black Ash item. Blame Habitat!
The problem with red dye is that it's especially "fugitive", so within a few years it'll be an insipid pink. If you can live with the inevitable fading then I'd use a water dye rather than a spirit dye, ignore the nonsense on the tin about spirit dye's being "light fast", they're hardly any more fade resistant than water based but they're much, much trickier to apply. All dyes need a wet edge to prevent tide marks and yet spirit stains dry within seconds. Spirit stains are terrific for french polishers and experienced finishers, anyone else should stick to water based.
