UKWorkshop Woodworking Forums
Post new topic Reply to topic  [ 10 posts ]
Author Message
 Post subject: Bleaching Walnut.
PostPosted: 12 Jan 2017, 19:44
Offline
Valued Contributor
Has thanked: 114 times
Been thanked: 192 times
Hello,
I made a blanket chest from American Black Walnut a few years ago, all finished except for the polish. Just after I'd done, I moved out of my workshop and with one thing and another, the chest got sidelined and never polished. At some point, the frame of the frame and panel lid got irreparably damaged. Now as we know, ABW does tend to lighten and become yellower with a bit of age and also, I suspect it was of the steamed variety, which seems to fade a bit. I liberated the panels and fitted them in a new frame, but the new walnut is darker. Probably kiln dried as it has the slightly purple tinge ABW gets when dried like that.
I'm thinking that a controlled application of Rustin's 2 part wood bleach will help to blend the frame in with the rest of the chest. I have used the bleach before a few times, but not for many years, and I do seem to remember that it has a yellowing effect on dark wood, which I want, and the loss of a little depth of colour. Does anyone think this is a reasonable plan? Obviously I'll do a test on some scraps, but am I on a hiding to nothing, or is it worth a shot? Should I just wait a few years for the frame to catch up with the rest? To my eyes it sticks out like a sore thumb!
Mike.
Share on Facebook Share on Twitter Share on Digg
 Profile
 Post subject: Re: Bleaching Walnut.
PostPosted: 12 Jan 2017, 19:51
Offline
Regular Contributor
User avatar
Has thanked: 172 times
Been thanked: 110 times
Wouldn't it be easier just to darken the panels maybe with some van dyke crystals?
 Profile
PostPosted: 12 Jan 2017, 19:59
Offline
Valued Contributor
Hello,
I thought of darkening, but there is an awful lot more to darken than there is to lighten. There are 8 panels to the chest, and their frames and the 4 posts as legs! It is still an option,but there is a slight complication. I previously finished the panels before I fitted them in the frames #-o TBH it is was the correct thing to do, as there is nothing worse than the panels shrinking a bit and exposing unfinished edges, but it makes it a pain in this situation.
Mike.
 Profile
PostPosted: 12 Jan 2017, 20:23
Offline
Valued Contributor
User avatar
Has thanked: 227 times
Been thanked: 1251 times
Tricky one that, I'm not sure I've ever bleached ABW, but I'd be concerned that a two pack bleach would remove pretty much all the colour and take it straight to drift wood. Plus, whenever I've had those "blending in" jobs I always seem to get better results when there's at least one step in the process that's applied to the entire piece, or at least if it extends some way beyond the patch or replacement part. It just seems to unify things that bit more than I can usually achieve working purely on a single section.
Good luck and let us know how you get on.
 Profile
PostPosted: 12 Jan 2017, 20:31
Offline
Regular Contributor
Has thanked: 1 time
Been thanked: 141 times
Mike, I suspect you might find it easier to blend the existing walnut to the new by dying rather than trying to bleach the new to the old. A/B bleaching isn't something I've ever been able to 'control' as you put it. In my experience, it either goes the whole hog and works, or it doesn't coming out patchy, therefore needing a second application.
However, if you took the route of doing a full-on bleaching job with the new material you'd end up with a uniform yellowish off-white which you could then colour up to match the existing older faded walnut: that might be as good a route as any, and probably the one I'd aim to attempt, after conducting an experiment or two on some scrap samples of course. Slainte.
_________________
richardjonesfurniture.com
 Profile
PostPosted: 12 Jan 2017, 21:08
Offline
Valued Contributor
Hello,
OK, I think I might have to get out the sander and take everything back to bare wood. Leaving the shellac in the panel edges probably won't show, they'll be in shadow, so the paler timber there shouldn't matter.
I'll gently stain the rest to try and get a match. Staining ABW seems contradictory to me, but I don't think I have a choice.
Mike
 Profile
PostPosted: 12 Jan 2017, 21:44
Offline
Valued Contributor
User avatar
ABW stains very well, I've done it plenty of times to blend in sap. I'd rather use unsteamed ABW with noticeable sap but lively colouration to the heartwood, than use steamed ABW with less noticeable sap but flat, dreary heartwood. You can build up to the colour you want with multiple applications of dilute dye and ABW takes colour a treat.
Good luck!
 Profile
PostPosted: 12 Jan 2017, 21:59
Offline
Valued Contributor
Hello,
Dying the wood doesn't frighten me, as such, just that I made sure there wasn't any sap when I made it, so I wouldn't need to!
You are right about the steamed stuff being dull, though. The timber merchant that is most amenable to me seems to have that as a rule. However, I got a batch recently, the stuff I'm using for this repair and for another job and I was feeling a bit saucy and asked for Super Prime as they call it. I suppose I should have asked, but I just assumed it would be the steamed stuff, but with more of the sap graded out. (I used to be able to pick through the stacks there, but they don't allow it now and I have to let them pick for me to collect). Now if I'm not mistaken, I do believe it is kilned rather than steamed as it does seem clearer in colour and the very little sap it has, doesn't have any colour to it. It also has the purple tinge to it that doesn't appear with air dried or steamed ABW. It seems a much better buy, despite it being dearer.
Mike. I
 Profile
PostPosted: 13 Jan 2017, 10:16
Offline
Valued Contributor
User avatar
Just read this month's Furniture & Cabinetmaker, there's an amazing piece that uses bleached Walnut, it's like bone or ivory.
 Profile
PostPosted: 13 Jan 2017, 14:05
Offline
Valued Contributor
Hello,
Interesting, I'll look out for that.
I suppose if you had a lot of very sappy walnut, it could be a good way of harmonising everything.
I was thinking of making a sideboard from American ash and bleaching that, as I really don't like the way it yellows over time. I don't suppose I'll do it now I'm not a full time maker.
Mike.
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 4 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
 Similar topics   Author   Replies   Views   Last post
Gladius in oak and walnut
in General Woodworking
Farmer Giles
17
723
07 Oct 2017, 16:04
Walnut Bowl
in Wood Turning - Lathes
Dalboy
3
482
08 Jun 2017, 20:45
european walnut dye
in Finishing Advice
ScottGoddard
2
343
10 Mar 2017, 17:36
British Walnut prices
Sawdust=manglitter
23
1172
19 Jun 2017, 10:37
African Black Walnut
Waka
7
335
10 Dec 2017, 19:27
Register UKW
User Tools
UKW Local
Quickly find the nearest tool suppliers & timber merchants in your area
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
UKW Terms & Privacy
