What's the norm for specifying measurements? I need a thumb turn, and it needs to 30mm/10mm/40mm - but everything I'm looking at gives 30mm/ 50mm, with no indication where the lever is or from which side they are measuring (I assume it's 30mm/10mm/40mm or the lever would be too close to the side ). It obviously matters with a thumb turn - on a thicker door it could be 50mm/10mm/40mm or 40mm/10mm/50mm. It's on Amazon so there doesn't appear to be a contact to ask.
