UKWorkshop Woodworking Forums
Post new topic Reply to topic  [ 15 posts ]
Author Message
 Post subject: Prototype 'Harlekin'
PostPosted: 04 Dec 2016, 01:40
Offline
Settling In
User avatar
Has thanked: 10 times
Been thanked: 20 times
A sash saw with a new designed handle. It was a test to give it a more TLT touch. More filigrane and offering a way to insert an ovally shaped spine flush to the top of the cheeks. Pedder isn't too fond of it, he called the design 'Harlekin'. I had a good laugh on this name but found it rather good. I like this design a lot. The pic shows a comparison to our usual sash saw handle.
The Cocobolo handled saw is my user for a few years.
More pics can be seen here: https://two-lawyers-toolworks.blogspot. ... &Itemid=58
Klaus
_________________
Two Lawyers Toolworks - Klaus & Pedder bauen Sägen
Share on Facebook Share on Twitter Share on Digg
 Profile
 Post subject: Re: Prototype 'Harlekin'
PostPosted: 04 Dec 2016, 09:01
Offline
Valued Contributor
User avatar
Has thanked: 59 times
Been thanked: 528 times
i like that. The only comment I have, and it isnt a criticism, is that the very dark timber doesnt show off the subtle lines and features like the cocobolo saw does. The blog pictures show a little more, but I can only see a hint of the feature at the bottom (is this called a lambs tongue?)
 Profile
PostPosted: 04 Dec 2016, 09:06
Offline
A Regular Member
Has thanked: 125 times
Been thanked: 61 times
Beautiful work Klaus. I like the flush look to the mortise line..
regards Stewie;
 Profile
PostPosted: 04 Dec 2016, 10:34
Offline
Settling In
User avatar
The rather dark Ebony hides the details while being photographed with the usual exposure. Here a few slightly overexposed pics.
You probably will spot some nicks and nacks. I was smart enough to drop this handle onto the floor when it was nearly finished. It was seriously damaged :( . Since it's a prototype that was made to show the shape and to judge the haptics, I glued the handle parts together instead of throwing them into the bin.
Klaus
_________________
 Profile
PostPosted: 04 Dec 2016, 10:35
Offline
Settling In
User avatar
Thanks Stewie.
Klaus
_________________
 Profile
PostPosted: 04 Dec 2016, 10:50
Offline
Valued Contributor
User avatar
Klaus
very nice indeed
 Profile
PostPosted: 04 Dec 2016, 11:10
Offline
A Regular Member
User avatar
Has thanked: 48 times
Been thanked: 98 times
Klaus
It is indeed very pretty. Dare I ask, though, if it was broken so quickly (I think I see the break in the lower horn) is the design not a bit too fragile ? What is the white dot on the top of the handle ? I've seen plugs covering a strengthening rod on some saws - presumably that's not the purpose ?
 Profile
PostPosted: 04 Dec 2016, 11:15
Offline
Valued Contributor
User avatar
Has thanked: 311 times
Been thanked: 194 times
Works of art, perfectly made.
_________________
Mike
'gotten'-free zone.
 Profile
PostPosted: 04 Dec 2016, 12:45
Offline
Regular Contributor
Has thanked: 92 times
Been thanked: 109 times
Your saws are by far the best and finest looking of any of the boutique makers I've seen. It really isn't even close.
 Profile
PostPosted: 04 Dec 2016, 13:48
Offline
Settling In
User avatar
Many thanks to all posters!
I've a tiled floor in my shop. If a handle drops down it almost always will get impacts regardless the wood or the shape. But the rather brittle Ebony is more vulnerable than e.g. beech or some fruit woods, no doubt. This particular design seems to be more fragile than others. But as you can spot, the bottom horn didn't brake where it's thin, the brake was on a relatively thick part. The long and thin horn ends are rather long grained, the brake has happened on a short grained part. The best idea with any handle is not to drop it down :lol:
The white dot is a Mother of Pearl inlay, so just an embellishment.
Klaus
_________________
 Profile
PostPosted: 04 Dec 2016, 14:07
Offline
Valued Contributor
User avatar
Has thanked: 161 times
Been thanked: 66 times
Lovely shape and execution but I'd be frightened to use it - I'm always dropping things and even though I've got rubber mats, my dropped tools always seem to find the concrete!
Rod
 Profile
PostPosted: 04 Dec 2016, 21:08
Offline
Participant
Has thanked: 17 times
Been thanked: 4 times
They both look awesome!
 Profile
PostPosted: 05 Dec 2016, 09:42
Offline
A Regular Member
Has thanked: 3 times
Been thanked: 85 times
I am impressed by your craftsmanship but I don't like the style at all. There is just not enough material and strenght in it. If it was mine I would break it very soon and that would be a wastage of your good craftsmanship.
_________________
I am not a native speaker of English so beware of translation misstakes. I think in Swedish and write in English.
 Profile
PostPosted: 05 Dec 2016, 09:52
Offline
Settling In
Has thanked: 2 times
Been thanked: 10 times
Love the saw, i'll be scared to use it.
Oli
 Profile
PostPosted: 05 Dec 2016, 18:03
Offline
Settling In
User avatar
I think that the tool has enough strength to stand hard use as long as it will be treated how a good tool should be treated. Look some early saws like Groves & Sons, Kenyons and others more. They show that a filigrane shape is able to stand the use for 150+ years.
Actually these early British saws did influence me a lot, when I began the saw making adventure together with Pedder. They show that a good performance and a lovely design can go hand in hand very well. It was the Victorian pride of toolmaking that created outstanding tools and that influenced the whole handtool world. It's one of my main motivations to get this kind of toolmaking back to life again. And: thanks godness there actually is a growing number of toolmakers, that obviously tries to achieve the same target. To make a well performing tool that is overdimensioned in some parts for reasons of precaution is easy. But nothing that for me seems to be worth it to spend my time. I want more.
Klaus
_________________
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Register UKW
User Tools
UKW Local
Quickly find the nearest tool suppliers & timber merchants in your area
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
UKW Terms & Privacy
phpBB SEO
