Cutting a slab of cheery wood has buggered by blade
craigjsmith
6 Apr 2016
Troon
Quick Question...
I am cutting slabs of cherry wood on my table saw and noticed that it has fair taken its toll on my blafe..
I have a freud 254mm 40 tooth blade....
Should i be using a different blade for these kinds of slabs? The slabs are about 50mm thick..
Thanks in advance guys
Craig
Both..... should i be using different blades for each??? Should i use a corcular saw instead????
e
Hello,
Yes, the 40 tooth is OK for rough crosscutting, but ripping 2 inch thick stuff, you need a dedicated rip blade. Ripping as you are will generate lots of heat and needs a slow feed fate. cherry is a pipper for burning with slow feed rates.
Mike.
