For the uninitiated, there's a gloat in there somewhere :lol: - RobWaka":abvwt5br said:Jolly good shavings what, not sure I can get my planes to take them that thin.
I don't see why you need a tight mouth for end grain.
woodbrains":1yqjrg6o said:I don't see why you need a tight mouth for end grain.
Planes for endgrain, such as shoulder planes and LA block planes have traditionally had adjustable mouths, to keep the opening slight. It is funny that isn't it?
I'm amazed at how many people make comments about not seeing the point of needing the cutter 'that sharp' or the plane's sole 'that flat' or the mouth 'that tight'. etc. etc. Once tried, however, they usually comment on having never before done work 'that good'. Also amusing!
Mike.
Wrong. I used David Charlesworth's low angle Holtey smoother at Rycotwood recently. The mouth on it was not adustable and was around 2mm wide - Robwoodbrains":j6tkqrhl said:... and an extremely tight mouth opening. As are planes by Karl Holtey
Mike.
woodbloke":24fo8l4l said:Wrong. I used David Charlesworth's low angle Holtey smoother at Rycotwood recently. The mouth on it was not adustable and was around 2mm wide - Robwoodbrains":24fo8l4l said:... and an extremely tight mouth opening. As are planes by Karl Holtey
Mike.
