Not registered?? Click HERE to join our community
The secret to cambering Bevel Up plane blades
Goto page Previous  1, 2, 3, 4, 5  Next
Post new topic   Reply to topic    UKworkshop.co.uk Forum Index -> Hand Tools
View previous topic :: View next topic
Author Message
Wiley Horne
Woodworker
Posted: Fri Oct 12, 2007 4:30 am Post subject: Reply with quote
Denis,
I'll write you offline, as I have unwisely jumped into the middle of Derek's story with an explanation--when he is infinitely more qualified than I to explain his results!
Wiley
Back to top
View user's profile Send private message Send e-mail
Derek Cohen (Perth, Oz)
Furniture Maker
Posted: Fri Oct 12, 2007 4:54 am Post subject: Reply with quote
Hi Denis
Let me start by saying that your questions are good ones. Even more than good - they are important and must be asked and answered.
The problem centres around the grind (a term I prefer when removing metal rather than polishing it) a significant camber on a bevel up blade. And to take this the important next step, to do so on a BU blade with a high bevel face, such as 50 degrees.
It is contended generally that a BU blade requires a greater camber for the same effect than a BD blade. This is due to the geometry of the bed, 12 degrees for BU and 45 degrees for BD.
It is my contention that there is less metal to remove - which makes the process viable - on a BU blade with a 25 degree primary bevel and a 50 degree secondary (micro) bevel. The foundation for this argument is that a microbevel is .. well, micro .. and a camber on the full face of a 50 degree primary bevel has considerably greater volume.
I would suggest that you try cambering a full face 50 degree bevel by hand and, if you can, do the same with a 50 degree micro secondary bevel on 25 degree primary bevel , and report back your experience.
Keep in mind that we are talking about creating shavings for not just a smoother, but especially for a fore plane - so see the camber profile that is needed to do this. The camber resembles that of a scrub plane with a BD configuration.
Regards from Perth
Derek
Back to top
David C
Furniture Maker
Posted: Fri Oct 12, 2007 7:22 am Post subject: Reply with quote
Andy,
Thank you so much for that encouraging story!
David
Back to top
View user's profile Send private message Visit poster's website
AHoman
Woodworker
Posted: Fri Oct 12, 2007 11:17 am Post subject: Reply with quote
David C wrote:
Andy,
Now we will just have to see what Derek's influence will be on our woodworking program -- will it be bevel-up planes, or will we have the kids make their own dovetail markers? (Or will I have them read Viktor Frankl?)
-A.
Back to top
promhandicam
Furniture Maker
Posted: Fri Oct 12, 2007 12:07 pm Post subject: Reply with quote
dchenard wrote:
Pardon me for being insistent, but the statement that one will remove more steel on a 50 degree bevel than on a 25 degree bevel just plain doesn't work. . . . Cheers, DC-C
Having read through the whole post, I think that, in your own ways both Derek and Denis are correct.
In the initial set up of converting a blade from straight to cambered then yes more steel has to be removed if you are grinding a 25 degree bevel as opposed to a 50 degree bevel. However once the basic shape has been produced, when it comes to sharpening, less steel will be removed if you add a secondary bevel onto a 25 degree primary bevel than if you are trying to hone the whole of a 50 degree face. Perhaps the following will illustrate what I'm trying to say:
The red lines indicate where the iron would be honed to get a 50 degree angle.
I hope this helps,
Steve
_________________
'Personally I'm always ready to learn, although I don't always like being taught' - Winston Churchill
Back to top
ivan
Furniture Maker
Posted: Fri Oct 12, 2007 1:39 pm Post subject: Reply with quote
I understood Derek to mean "metal removed on the honing stone". If you have a 25 deg primary bevel you don't have to remove much steel to hone it - it's a microbevel, even if honed at 50 deg. If you grind at 50 deg, you then have to remove metal from the whole face of the bevel to hone it (also at 50 deg). This right?
Back to top
dchenard
Furniture Maker
Posted: Fri Oct 12, 2007 2:14 pm Post subject: Reply with quote
I hope this helps,
Steve
Totally agree. Might be the term selection (grinding/sharpening/honing) that created the confusion...
Blame it on a language difference, as neither Derek nor I have English as their first language Laughing
I'll get my coat now Mr. Green
DC-C
Back to top
Furniture Maker
Posted: Fri Oct 12, 2007 2:49 pm Post subject: Reply with quote
Steve
Thank you for clarifying that point. It is amazing in how many ways the same sentence might be (mis)interpreted.
Here is what I originally wrote:
Quote:
Here it is in a nut-shell … grind the primary bevel on all plane blades to 25 degrees. Don’t try to camber any blade that is greater than this, such as one with a 38- or 50 degree primary bevel
Regards from Perth
Derek (who is indeed bilingual, but admits that he has no excuses as English is his first language)
The DC Club
Back to top
dchenard
Furniture Maker
Posted: Fri Oct 12, 2007 3:54 pm Post subject: Reply with quote
promhandicam wrote:
Having read through the hole post, I think that, in your own ways both Derek and Denis are correct.
I hope this helps,
Steve
Time for a mea culpa Embarassed
Looks indeed like I did not interpret Derek's statement properly. As exposed here by Steve, I do not have any argument.
Furthermore, and this is where I must admit being red-faced, in my example where one grinds a camber on the whole face of a 25 degree bevel iron versus the same on a 50 degree iron, I've maintained that the 25 degree iron will require more metal being removed in order to form the same camber. Thanks to Wiley, I must admit that I was wrong d'oh!
In fact, no matter what the bevel on the iron, grinding a camber on the whole bevel of an iron will result in the same amount of metal removed, no matter what the bevel angle.
The point that I neglected was that, as the bevel angle goes down, the "effetive thickness" of metal removed to produce a camber goes down at the same time that its length goes up. Think "long and thin" versus "short and fat".
Definitions:
BLT: blade thickness
BET: "effective thickness" of metal removed
BL : bevel length
C : camber of the blade
(theta): bevel angle of the iron
The equations go like this:
BL = BLT / sin (theta)
BET = C sin (theta)
The section of metal removed at any point over the width of the blade is a parallelogram in section, which area can be computed as a rectangle of length BL and thickness BET. Multiplying the two, we get:
Section = BL * BET = BLT * C
Notice that the angle of the equation get cancelled out, or in other words, the bevel angle has no bearing on the amount of metal being removed, only blade thickness and amount of camber matter.
Thanks to Wiley for clarifying this occasion5
DC
Back to top
ivan
Furniture Maker
Posted: Fri Oct 12, 2007 4:15 pm Post subject: Reply with quote
PS. I assume there's little advantage in using the JET cambering jig? This one looks a good deal more affordable....
Back to top
David C
Furniture Maker
Posted: Fri Oct 12, 2007 8:23 pm Post subject: Reply with quote
Ivan,
I have been using that New Jet jig, (which fits Tormek) and have written about it and camber in general, in the issue of F&C which is out about now.
It does a very good job on gentle and medium camber, may or may not do enough for a scrub plane, didn't have time to find out.
I like it a lot.
David Charlesworth
Back to top
ivan
Furniture Maker
Posted: Sat Oct 13, 2007 9:54 pm Post subject: Reply with quote
Thanks, David; I'll keep a lookout for the mag. but newsagents are a rare item in these 'ere parts.
Back to top
David C
Furniture Maker
Posted: Sun Oct 14, 2007 7:40 am Post subject: Reply with quote
Ivan,
There is one at the bottom of Bideford high street!
Where are you?
David
Back to top
bugbear
Master Cabinetmaker
Posted: Mon Oct 15, 2007 7:53 am Post subject: Re: The secret to cambering Bevel Up plane blades Reply with quote
Derek Cohen (Perth, Oz) wrote:
The result is a cambered 25 degree primary bevel ….
And, yes Bugbear, the camber does indeed match the template! Look …
I never denied that it would; my point was, and remains, that the blade camber is generated by your skill and care, not the template.
None of which is to deny the demonstrable fact that your procedure generates the blade you desire.
BugBear
_________________
Grinding, sharpening and polishing are really very interesting operations.
...William Henry Bragg
Back to top
David C
Furniture Maker
Posted: Tue Oct 16, 2007 6:49 am Post subject: Reply with quote
BB,
I was going to point out the same thing.
The skill required is to keep the long stick at the same angle.
A support at the top end of the stick would help to maintain consistent angle, would it not?
best wishes,
David
Back to top
Display posts from previous:
Post new topic   Reply to topic    UKworkshop.co.uk Forum Index -> Hand Tools All times are GMT
Page 2 of 5
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
UK, tools, machinery, woodworking, DIY, wood, drills, saws, power tools, second hand machinery, table saw
Powered by phpBB © 2001, 2005 phpBB Group
UKW Terms & Privacy
Follow UKWorkshop on Twitter
