Not registered?? Click HERE to join our community
Spray finishing MDF edges - How I do it
Goto page 1, 2  Next
Post new topic   Reply to topic    UKworkshop.co.uk Forum Index -> Finishing Advice
View previous topic :: View next topic
Author Message
Richard Findley
Master Furnituremaker
Posted: Fri Mar 27, 2009 11:58 pm Post subject: Spray finishing MDF edges - How I do it Reply with quote
Hi all,
Let me start by explaining that I am relatively new to spraying and have learned through a combination of trial and error and hints and tips picked up from people in the know and of course the forum!!!
Here's what I do (and the products I use)
Cut MDF to size and run a hand plane over to remove machine marks. Rout mould (or in this case chamfer):
Hand sand with 240grit - Carefully!!
A coat of Morrells White Primer 8005/641 (Waterbourne)
This appears quite rough still but a light hand sand with 400grit removes all fluffy bits and leaves a smooth finish:
2 coats of Morrells 362 "Severe Use" Waterbourne Lacquer gloss white. I've found that there is no need to rub down in-between coats. In this case I also finished with a coat of clear 90% gloss as there was another detail on the surface that needed a coat to even the gloss all over:
I hope you have enjoyed reading this and that it is of some help to someone out there.
Cheers,
Richard
_________________
Woodturning by Richard findley at www.turnersworkshop.co.uk
My Workshop tour http://www.ukworkshop.co.uk/forums/viewtopic.php?t=28748
Back to top
View user's profile Send private message Visit poster's website
JonnyD
Furniture Maker
Posted: Sat Mar 28, 2009 6:43 pm Post subject: Reply with quote
Hi Richard looks like you have got a good finish there pretty much how i do it.
I was just wondering how you got on with the morrells waterbased top coat. I usually use morrells Acid Cat lacquers but have been meaning to give the waterbased stuff a go and do my bit for the environment. I have tried the waterbased primer and was impressed by that.
Jon
Back to top
Richard Findley
Posted: Sat Mar 28, 2009 7:05 pm Post subject: Reply with quote
Hi Jon,
I've been very impressed by the waterbourne finishes. I don't have a spray booth so fumes are a bit of an issue for me. These finishes are touch dry in 1 hour and recoatable after 2 which is really the only down side compared to chemical finishes. They reckon that these waterbourne lacquers are pretty much as hard wearing as the chemical ones. The clean up is a lot easier with waterbourne. Just run under the tap and spray water through!! I love 'em!!
Cheers,
Richard
_________________
Back to top
Paul Chapman
Master Cabinetmaker
Posted: Sat Mar 28, 2009 7:06 pm Post subject: Reply with quote
Looks good, Richard. What sort of MDF was that - ordinary or MR?
Cheers Wink
Paul
Back to top
View user's profile Send private message Send e-mail
JonnyD
Furniture Maker
Posted: Sat Mar 28, 2009 7:47 pm Post subject: Reply with quote
Cheers Richard
I will give the waterbased a try. I am making myself some wardrobe doors so I will try it out on these before using it on any paid work.
Jon
Back to top
cornucopia
Cabinetmaker
Posted: Sat Mar 28, 2009 7:59 pm Post subject: Reply with quote
looks like you have achieved an excellent finish richard-well done Smile
_________________
______________
Vol4-Cornucopia
MY WEBSITE
Back to top
View user's profile Send private message Blog Visit poster's website
BradNaylor
Master Cabinetmaker
Posted: Sat Mar 28, 2009 9:33 pm Post subject: Reply with quote
That looks like bog standard fluffy MDF, Richard.
You will find that the edges of MR MDF finish a lot more easily. Well worth the small extra cost.
I too use Morrells AC finishes. I might give the waterbourne ones another try.
Dan
Back to top
View user's profile Send private message Send e-mail Blog
Richard Findley
Posted: Mon Mar 30, 2009 8:35 am Post subject: Reply with quote
Hi guys,
Thanks for your comments. Yes, this is bog standard MDF. I've heard a number of times on here that MR MDF is far better so I may well try it next time.
Cheers,
Richard
_________________
Back to top
imaginarynumber
Forum Newbie
Posted: Sun May 24, 2009 1:34 pm Post subject: Reply with quote
Hi Richard-
Re the waterbourne- are you using a compressor or turbine??? Do you get grain swell with the water based primers?
I too have only ever used the acid cat
Back to top
Richard Findley
Posted: Mon May 25, 2009 7:46 am Post subject: Reply with quote
Hi imaginarynumber,
I used to use a little Apollo "Spray master" HVLP system which was ok but when I started having troubles with the gun I bit the bullet and bought a compressor and proper spray gun.
I now wonder how I ever managed without my compressor and the finish with this gun is much improvroved as the gun is so adjustable you can tweek it to suit your needs.
The waterbourn is a great finish and it doesn't seem to raise the grain significantly. I had some slatwal panels made for me a while ago and they used some cheapo rubbish MDF which I have struggled to get the sort of finish I would like on but as you can see from the pictures adove, normal (good quality) MDF finishes well, as does timber.
HTH
Richard
_________________
Back to top
imaginarynumber
Forum Newbie
Posted: Mon May 25, 2009 2:12 pm Post subject: Reply with quote
Thanks Richard
Not sure that I have enough space for a decent compressor so i guess that I will have to stick with my Fuji HVLP.
I generally stick with acid cat as the gun is happy with it.
Although you say that the grain raising isn't too bad should I take that too mean that it is noticably more than acid cat primer???
When hand painting with acrylic primer I expect to spend as long sanding as I did applying the paint; generally back to the point where you see the parallel machining lines.
In your case are you sanding to denib or to flatten raise bits of grain.
Back to top
yo_chuci
Furniture Maker
Posted: Mon May 25, 2009 3:27 pm Post subject: Reply with quote
what type of spray gun did you buy and from where...
is it hvlp?
_________________
Yo_Chuci
"Time flies like an arrow, fruit flies like a banana"
Back to top
Richard Findley
Posted: Tue May 26, 2009 11:03 pm Post subject: Reply with quote
Hi imaginarynumber,
What I said was: "The waterbourn is a great finish and it doesn't seem to raise the grain significantly"
I've not had any grain raising problems with it (appart from this crappy slatwall MDF) but I must admit to not having that much experience with Acid Cat finishes.
Hi yo_chuci,
My gun is a De-Vilbiss Signature gravity fed HVLP gun from Morrells. It cost me about £275, so not cheap but it's a fantastic bit of kit!! There are MUCH cheaper guns out there for the occaisional user. I've seen them from about £35 from places like Axminster.
As far as I understand it, there's nothing really wrong with the cheaper guns but they are pretty much "disposable" so you bin them if you have any trouble with them/if parts start to wear etc and buy a new one. With the dearer guns like mine, all of the parts are replaceable and servicable so (hopefully) will have a longer life span!!
Richard
_________________
Back to top
white_sw
Furniture Maker
Posted: Thu May 28, 2009 8:17 am Post subject: Reply with quote
From you pictures, it looks like to have a fantactic finish there. I've heard lot's of good stuff about these Morrells finishing products.
Does anyone know where I can buy some in Bristol ? I wouldn't be using large amounts as it just for hobby use. I have my own
spray setup, however, have only sprayed cellulose paints on car's before.
Cheers,
Sam
Back to top
dellpitch
Forum Newbie
Posted: Sun Jun 21, 2009 8:59 pm Post subject: Spray finishes Reply with quote
Hi
Morrells have a Bristol depot, it is at Avonmouth, on the road to
Severn Beach, Tel 0845 4509070.
hope this helps
_________________
NormanD
Back to top
View user's profile Send private message AIM Address
Display posts from previous:
Post new topic   Reply to topic    UKworkshop.co.uk Forum Index -> Finishing Advice All times are GMT + 1 Hour
Goto page 1, 2  Next
Page 1 of 2
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
UK, tools, machinery, woodworking, DIY, wood, drills, saws, power tools, second hand machinery, table saw
Powered by phpBB © 2001, 2005 phpBB Group
UKW Terms & Privacy
Follow UKWorkshop on Twitter
