UKWorkshop Woodworking Forums
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Author Message
 Post subject: Re: Record T5?
PostPosted: 23 Jul 2017, 19:49
Offline
Prolific Contributor
Has thanked: 603 times
Been thanked: 1014 times
One way of finding out - give it a go.
 Profile
PostPosted: 23 Jul 2017, 19:59
Offline
Regular Contributor
Has thanked: 93 times
Been thanked: 109 times
Chris152 wrote:
Chris152 wrote:
phil.p wrote:
Yes ... if you're going to paint the finished product.
Ah, right - do you end up with an ugly glue line?
Anyone? Can a well set up table saw with the right blade produce a decent edge for jointing? I've no doubt a plane in the hands of a skilled cabinet maker would be better, but could a table saw bridge the gap til I can produce such an edge by hand?
It's possible with a very solid saw with a glue line rip blade installed. You need a good bit of motor to push a blade like this -- 3 hp minimum, 5 hp much better.
 Profile
PostPosted: 24 Jul 2017, 10:36
Offline
Settled in Member
Has thanked: 27 times
Been thanked: 15 times
Hmmm, I don't have a table saw and it'd have to have been a cheap one, so no chance of 3+ hp.
So, reading back through the posts above I decided to make this this morning - a shooting board in the vice, feels way more ergonomic than when horizontal and with gravity to assist the cut.
The grips are there to hold the wood in place as I lift it into the vice and, after shaving a bit of hair off my arm, I found it works a treat. I need to make a longer one (1m) for the boards I want to glue together, so we'll see if that works as well.
Thanks all for your thoughts and patience!
 Profile
PostPosted: 24 Jul 2017, 11:29
Offline
Settled in Member
User avatar
Has thanked: 12 times
Been thanked: 75 times
How are you gonna surface those wide boards Chris ?
That's normally done before the edges.
If you don't have a workbench or surface to plane on, that's what you should focus on.
You could even stick a fire door on a flat surface and clamp a baton to the end for a planing stop
that would be fairly handy.
You soon would not want a fixture for a long grain shooting board, as stock that wide will easily sit on the bench.
Tom
 Profile
PostPosted: 24 Jul 2017, 12:28
Offline
Settled in Member
I have another bench with a vice which I've been planing flat sides with, but it's a temporary setup, Tom. And they won't be as wide as the one in the picture, that's just a piece I had in the garage that I thought I could try the shooting board on. I'm reckoning the surface of the table can be a bit more forgiving in terms of accuracy than the joints along the boards for glueing...
 Profile
PostPosted: 24 Jul 2017, 12:43
Offline
Settled in Member
User avatar
Why fight a good thing ?
A well set plane will produce no tearout.
To get these results, it requires finer shavings depending on species.
You can then be sure you will get accurate joints afterwards as you can check your work more accurately.
A flat bench is essential IMO
I should have took a picture of the amount of fire doors that was down in the dump the other day.
One of those would sort you out for planing boards up.
Tom
 Profile
PostPosted: 07 Aug 2017, 22:25
Offline
Settled in Member
My first attempt to join boards to make a small table top. (Three pieces of pine jointed.)
I built a 1m shooting board to joint the boards along the grain and it seems to have worked fine. The glue-up wasn't tidy looking but it seems to have worked ok, some planing and it looks good to my eye.
Which just leaves the question of how I trim the ends. I've seen a small table saw for a good price (Axminster ts200), but it still scares me and a cheap track saw saves some money. With a decent cut, it shouldn't take too much finishing by hand with sandpaper? Track saw or table saw. hmmm...
 Profile
PostPosted: 08 Aug 2017, 07:24
Offline
A plane. :)
 Profile
PostPosted: 08 Aug 2017, 07:56
Offline
Settled in Member
phil.p wrote:
A plane. :)
Can't help but feel 45 cm of end grain is a bit outside my comfort zone for the moment!
 Profile
PostPosted: 09 Aug 2017, 06:47
Offline
Settled in Member
User avatar
Has thanked: 1 time
Been thanked: 14 times
Adding a fence to your jointer plane would be easier
_________________
Occasional musings on my blog:
https://bridgerberdel.wordpress.com/
 Profile
PostPosted: 10 Aug 2017, 17:39
Offline
Settled in Member
I don't have a jointer but could try attaching a fence to the wooden plane as someone suggested in another thread. Tho I'm just happy to have something that works and feels stable for the moment.
It turns out that my hand sanding is far from accurate - I got a nice finish with paper but it wasn't at all flat and perpendicular to the faces of the table top, so I attached grades of paper to square section blocks of wood and lifted the table top, and ran the block along the bench top which keeps it square. The saw blade marks are still visible so I'm hoping a finer tooth blade on the track saw will be easier to clear up after.
 Profile
PostPosted: 10 Aug 2017, 17:58
Offline
Settled in Member
User avatar
That's a big waste of time to sand joint pieces, not to mention the possible grit impregnated into the timber that would stop a joint going together as good as it could be,
not to mention just the better finish for glue in general.
More important in instrument soundboards and the like, but it makes sense.
Did the camber not work out for you?
You did mention having two irons ...
Tom
 Profile
PostPosted: 10 Aug 2017, 18:09
Offline
Settled in Member
The boards are already jointed Tom, I planed the edges to joint then glued, trimmed the ends and now I'm trying to get a decent finish on them - which seems to work.
 Profile
PostPosted: 10 Aug 2017, 18:18
Offline
Settled in Member
User avatar
Well I sit corrected :)
Although my point still stands, as that grit could contaminate some other surface
I just have a thing about sanding :twisted:
Why did you not just plane it?
Tom
 Profile
PostPosted: 10 Aug 2017, 21:24
Offline
Settled in Member
I want to keep practising planing end grain, but tbh my skills just aren't up to 45cm of it. And I'm surprised what a great finish sandpaper can produce - I used 120 followed by 250, and it had a real polish to it. And very little dust - it didn't take so much work (though there are still traces of the blade - I'm going to recut it tomorrow to see if a finer tooth blade needs still less).
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 16 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
 Similar topics   Author   Replies   Views   Last post
Record cl3
in Wood Turning - Lathes
Ant-h83
2
244
09 Dec 2017, 15:08
Record 071 Project
in Hand Tools
rxh
18
927
06 Nov 2017, 21:36
Record 044 skate
in Hand Tools
MarkDennehy
13
299
15 Jan 2018, 11:42
Record BS250 set up
in General Woodworking
Griffin
12
607
15 May 2017, 14:42
Record dml320
vinceboat
2
553
26 Mar 2017, 11:04
Register UKW
User Tools
UKW Local
Quickly find the nearest tool suppliers & timber merchants in your area
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
UKW Terms & Privacy
